timing light
timing light
hey gents i got a timing light on ebay awhile back and i only used it a few times to set my base timing. it has the dial back **** on the gun for setting total timing but i dont have the instructions for this gun and have no clue how the dial back works. any ideas how this thing works? thanx
Those dial back lights with built in retard/advance feature, particularly the cheaper ones, are notorious for being inaccurate, anywhere from 2-10 degrees inaccurate!
Also, they won't work with MSD ignitions which iirc your truck has.
Use five different dial back lights and I bet you get five different readings.
Just use some timing tape, a tach, and an "old school" fixed timing light to check/set total.
riverguideguy, with a dial-back light, and the engine at 3000rpm, turn the dial clockwise and you'll see the timing mark on the balancer "retard" and move closer and closer to the 0-degree mark on the timing tab. Keep turning the dial until the timing mark lines up with the 0-degree mark, check to see how many degrees you've dialed in on the light, and that's your total timing. Easy!
Those old Sears timing lights are some of the best, I still use an 80's era Sears/Craftsman timing light (inductive) works like a charm.
::: DRO ::: Tech Section - In Tune with the Times - 10/7/05
That's old old school
Agreed!
Those new fangled dial-a-degree lights have too many moving parts for me...
Just use your "real" (read old school) light, read the degrees at the pointer at your desired RPMs....adjust advance accordingly, and, POOF! You're done!
That's correct, you should be able to set base timing when the light is set to zero and/or the dial back **** is turned off.
But once you set the dial back **** to 32-38 degrees to check/set total timing and rev the motor to 2500-3000 rpm the multiple spark discharge i.e. MSD will "confuse" the light and you'll never get an accurate reading.
119er
08-07-2013 06:58 PM
Gr8ride
01-28-2008 06:23 PM
mshumack
09-19-2002 02:44 AM
