another 2wd to 4wd question
I know this topic has been ran into the ground by everyone wanting to turn their 2wd into a 4x4...yes I know its better to sell your 2wd and just buy a 4x4 but I want a challenge,I have a perfectly good 86 Bronco that just needs an engine but after reading all the posts of converting the 2wd I think I want to give it a shot after all its completely a bolt in job as the frames are almost identical with the exception of the passenger side frame rail not being boxed in, that's why I'm here asking a question today,I know some people who have done this exact conversion who have not boxed in the frame rail and it leads me to wonder if that could cause problems down the road? Could the frame rail crack from not having that extra reinforcement or will it not really matter if you don't abuse your truck? I have an 88 2 wd that Ithought might be fun to "convert" with my Bronco parts... How would you "box" in the passenger side frame rail like the factory 4x4's? Only thing I can come up with is a piece of c channel
I agree with Jas, it's no issue. I converted the '92 in my sig from 2wd to 4wd last summer. Got my parts from a 1990 F150 with a blown engine and just took the entire drivetrain and swapped it into my '92.
Feel free to PM me if you have any questions about the conversion, since I obviously have the experience of doing this.
Ford would do anything to save a buck. That's how companies work, they try to save as much money as possible but still give a good product. So do you really think that Ford would put the time and money into engineering and developing their frame set up just to have a useless portion of it? The boxed in part is there for a reason, and if Ford saw fit to put it there, then I would go ahead and box it in on the 2wd. But that's just my opinion
If you really find it necessary to box in that side of the frame, then by all means go for it. But I didn't even mess with that. I have ridden my truck pretty damn hard on some trails while off roading, and I have had no issues. I'm only 18 and I accomplished this fairly easily. Air powered tools make it a heck of a lot easier, especially when you live in the Rust Belt.
How do you get the 4 low and 4 hi lights to work in the dash? I've heard the wiring is all there on these year models but I've also heard there isn't any wiring...I'm ocd so if I do this everything has to look and perform like factory or it will drive me nuts!
On my '92, there was a wiring plug attached to the transmission crossmember with a cap over it. I took the cap off and hooked it up to the wiring plug from the transfer case. My 4x4 light in the dash still doesn't work, for whatever reason. But I mean it's not very hard to tell if you are in 4wd with a manual shift transfer case
on
Oh yea I understand the wanting to say ha! I did it to all the critics who say it isn't worth the trouble....let me just run something else by you guys and get an outside opinion...I also have a super clean 78 f100 long bed 2wd and I have access to a rusted out 78 f150 4x4 with a good chassis and I know Alot of guys take these 73 to 79 trucks like mine and put them on aa 4x4 chassis of a similar year...basically unbolt the cab and bed and swap bodies....which do you think would be less work and would be the overall neatest truck as a 4x4 the 78 or the 88?
