Oil Dipstick length
Try this link...
Try this link and see if perhaps someone there can help you: Modular V8 (4.6L, 5.4L) - Ford Truck Enthusiasts Forums
78 f100 dipstick lenth
The oil dipstick in my 1978 truck with the 300 inline 6 engine is 18" long. It bottoms out in the pan and actually has a slight bend caused by it hitting the bottom. As a result, I get very high oil level readings WAY past the full mark even though I just changed the oil and I know that there is only 6 quarts. Obviously either it's the wrong dipstick or the tube has been replaced with one that is shorter than the original. Should I just mark the stick at the full mark where it shows now that I just changed oil with 6 quarts and just not worry about it? If so, where should I make the low level mark?
If you want to put a full and low mark on the current stick, then put 5 quarts and mark that as the low level. Then add the 6th quart and mark that as the full level.
EDIT: I found that depending on how the dipstick tube is mounted determines the length of the dipstick. This mounting was changed depending on what vehicle it was intended for.
I can measure my current stick of you would like, but the length may vary depending on how yours is mounted.
How many qts of oil should the 300 take if changing the oil & filter?
If I follow what you posted above with a new filter, 5qts mark low, 6qts mark high, I now start and run the motor and fill the filter with a qt of oil I would now be at the low mark no??
Dave ----
Thanks I will have to remember that when I go and start mine as I can't remember how much I put in but should be safe for a startup as I think it was only 5.
So being it takes 6 qts what I said above holds true.
Dave - - - -
Dave - - - -
skoop
Oil & Lubrication
13
11-11-2002 10:40 AM
