engine swap
Old Apr 4, 2013 | 01:57 PM
spankmystang's Avatar
spankmystang
engine swap
I want to pull 302 out of 1979 ford f150 2wd and replacing it with 300 6. The truck is automatic c4 my question is can I use same fly wheel and engine space plate and starter. The 6 cyl was mated to 4 sp with granny gear.Can anybody help?I also want to use same flywheel from 302.
Old Apr 4, 2013 | 05:56 PM
jim collins's Avatar
jim collins
The 302 will take a 28oz. or a 50oz. depending on what year it is. The 300 inline 6 uses a 0 oz. balance , wrong flywheel will make it shake enough to knock the bearings out in short time. They will bolt on but that does not mean it will work. 79 302 will be 28oz. balance.
Old Apr 5, 2013 | 02:00 AM
spankmystang
the right flywheel
How do I find the right flywheel for this swap 302 to 300 6cyl?
Old Apr 5, 2013 | 02:39 AM
defiantoutlaw's Avatar
defiantoutlaw
I would call COLLISTRUCKPARTSONLINE in Northampton PA. They usually have the answers for these questions, and have anything truck related in stock. They ship. They are great guys, Ive been dealing with them for 25 years now. Ive built many a rig using thier used parts and knowledge. Guarantee theyve got your correct flywheel.
Welcome to Collis Truck Parts Inc!!!
Old Apr 5, 2013 | 06:58 AM
jim collins
I'm not understanding your question. Are you wanting to put a 300 inline 6 up to a c/4 transmission ? If so we need to be talking about flex plates for automatic transmissions ,not flywheels for standard transmissions. I'v never had a 300 /6 in front of a c/4 so i don't know what it takes to do it . I just know on a standard you have to make sure you a using the correct flywheels or you will have problems. I will pass on giving anymore advice and leave it to others, sorry.
Old Apr 5, 2013 | 07:02 AM
fordman75's Avatar
fordman75
I gave you all the info in the other post you asked this on. https://www.ford-trucks.com/forums/1...r-7-3-idi.html
Being a truck, if it was stock, it will have a 164T flexplate.
Old Apr 5, 2013 | 07:36 AM
jim collins
__Yeah, i just checked back on that posting and you gave him all of the information he needs, more than i had. I don't understand the problem unless he wants to be it repeated a few times.__
Old Apr 5, 2013 | 03:42 PM
spankmystang
the one in the truckis stock as far as I know thats a C4 mated to 302.I want to put a 300 6cyl from another truck thats mated to a 4spd.and my question isi want to find one that has 0 bal?
Old Apr 5, 2013 | 04:40 PM
jim collins
__YES____FLEXPLATE FOR AUTO TRANY___FLYWHEEL FOR STANDARD TRANY__
Old Apr 5, 2013 | 06:56 PM
fordman75's Avatar
fordman75
I give up!
Old Apr 5, 2013 | 08:51 PM
jim collins
I give up!
___Yep me too.__There's an old saying " you can lead a horse to water but you can't make it drink".___
78F-250
May 19, 2009 10:41 PM
fordman17
Jun 5, 2007 07:39 AM
paden
Feb 12, 2007 08:07 PM
hav24wheel
Jul 20, 2006 11:52 AM
3tree
Jun 20, 2005 04:42 AM
