Virginia's April Fools BS thread!
#91
I did!!!!
Intake and carb are still here, but they are for a windsor, so that's not good news.
Cam is as follows;
Hydr flat tappet
351 c- boss 351-351 m-400
part # VS320-16
grind 10329
Use 1.73 rocker arm
Lift-Intake 2800 @ valve 484
lift-Exhaust 2947 @ valve 510
Intake cam timing- at tappet-1050 opens 58 btdc closes 29* abdc
Max lift 107*atdc 204 durration
Exhaust-1050 opens-44*btdc closes 10*btdc
max lift 117*btdc 214* durration
DO NOT USE WITH EXHAUST VALVE ROATORS
This may be too nasty of a cam to be practical in a truck..... Tim?????
you definately will need a vacuum can reserve for your power brakes
Cam is as follows;
Hydr flat tappet
part # VS320-16
grind 10329
Use 1.73 rocker arm
Yeah, might be a little much. Oh well.
An Edelbrock Performer intake be good, you think?
#92
That is an excellent intake. With the carb you have it will wake up the bottom end, and probably give you a tad better gas mileage.
Add a set of headers, and it will really wake up
#96
I did!!!!
Cam is as follows;
Hydr flat tappet
part # VS320-16
grind 10329
Use 1.73 rocker arm
Cam is as follows;
Hydr flat tappet
part # VS320-16
grind 10329
Use 1.73 rocker arm
What is the rear gear ratio?
#98
I would classify that as an aggressive street cam. It has a lot of lift but its kinda short duration. A vacuum cam would make sure the brakes and heater have enough vacuum to work. Headers will tame it a bit to so it should work. I would like to see some head work and a tall double plane intake as well to make sure torque doesnt suffer.
I figured I might as well pull the heads and strip them down, do a little porting and polishing, and then lap the valves while I have both manifolds off.
#99
Received 5,132 Likes
on
#101
on
#102
Where's the fun in that, Gerry?? These will yield better lower-end. I also won't have to unbolt the motor mounts or shield the starter with these. I'm hoping I'll be able to do these for under $300; need to figure out how many bends I'll have to order..
#103
I'm not going, too far. Besides---crazy weather...it's 12* warmer here in NY than our place near Stuart.
#104
If you want to stick with a tri-y instead of equal length, you may want to think about re-routing the tubes so that every other cylinder merges instead of 2 back to back. It helps with the scavenging because of the firing order.
So 1 - 3 merge and 2 - 4 merge then those to y's merge at the collector.
Please note, I am definitely not a header expert! Just remember reading some of that stuff in old hot rod and carcraft magazines.
#105
on
