215/223 alternator conversion
I've searched Google and wasn't successful. I'm trying to find a picture or someone who has converted their 215/223 from a generator to an alternator. I'd like to see the bracket and how the alternator attaches.
If you have done this conversion yourself, I'd greatly appreciate a brief pictoral and/or written "how-to".
As per Ross's suggestion, I may switch out to a 6v pos alternator and ditch the stock generator.
I used a Delco 3-wire. Here are a couple of links that explain the setup, etc. I used the factory generator bracket and a couple of washers, threaded rod and some nylock nuts. I slid the threaded rod through the factory bracket that bolts to the block. The threaded rod acts as the pivot point for the bottom of the alternator and then the original generator bracket arm bolts to the top of the alternator for your adjustment.
The Delco 10-SI and 12-SI Alternators
Catalog
OneWireAlternator
As for the 6 volt alternator. If you are staying 6 volt than you have to go that route but if you are upgrading/updating to 12 volt, I highly recommend the 3 wire setup, even over a one-wire setup. The 3 wire is out of an early 84 Cheby Camaro, 305, 4 bbl. The reason I like it is the cost factor, the easy availability and easy of use. GM one-wires cost more, sometimes harder to get a the local NAPA store on a Saturday afternoon and it's about the same hooking it up as a 3 wire.
Catalog
OneWireAlternator
JMHO, but if I were converting to an alternator, I would convert to 12 volts negative ground. You are already non stock so why not have the advantages of 12 V? As mentioned, the three wire GM alternators are readily available and cheap. Sell that expensive Optima six volt battery and move on. Again, JMO.
Thank you for the info and the pictures. If you can still get a picture of the bottom mount, that would be great. No sweat if you can't.
I've decided to go ahead with the alternator conversion, but not a 12v conversion yet. I'll hold onto the generator to have rebuilt later for "just in case".
Didn't forget about you, just got busy today. Look for it tonight or tomorrow. Thanks.
Bowsandovals
07-12-2016 07:48 PM
Tumblindyce
08-17-2009 11:24 AM
Paso1
01-30-2009 03:43 PM
