Broken stud won't come off. Drill ??
It 99 Expedition 5.4L 4wd
It had rot out manifold and 2 broken studs.
Long story I end remove 6 studs with mig welders they were PITA.
Last stud on #4 cylinder on top tried remove it wouldn't bugled. broke 3 nuts weld to it.
I am scare if that stud are behind coolant? What I should to do before drill though there?
What I did after #2 weld on last stud it broke and stud was barely stick out head. That was most RISK I ever did.
I heat around stud with propane torch for couple mins then spray pb blaster. Do this for 4 times then put washer and do tack with welder on MAX HI with slow feed wire. It turn washer to glow red after tacks many it filled up washer. Then weld nut to it. Keep heat. It was so glow RED. Hit with pb blaster until it little glow then I loose it came off. I was nearby to death of stress.
BEAVER
08-22-2002 05:49 AM
