RISKY TRANNY REPAIR
According to this: Ford Transmission Spotter's Guide .: Articles
The 4R70W was introduced in 1994. Assuming this is correct you could source a used transmission from a 1994 or later model truck.
How many miles are on it?
If you're going to be doing this yourself, just go ahead and drop the transfer case and replace the gasket between the tranny and transfer case.
I'm pretty sure the 4R70W was introduced mid way through '93 for F-Series trucks since it had the more desirable gear ratios for a truck than the AODE does. But, I could be wrong. And I don't know off the top of my head which years will interchange, because there's always the chance that there could be internal wiring harness changes.
If there are any differences between 95 and 96, I bet they are electrical only. Both of those transmissions will use the older method of internal wiring, which is to use actual wires. 98+ 4R70W's have a plastic tray with individual conductors instead of using individual wires.
So if there are any electrical differences, they would likely be things like different EPC solenoid, TCC solenoid, etc. Different not in shape, but rather by impedance. I know I had to swap a few components around when replacing my 97 4R with a 98 model.
Honestly though, I really don't think there is a difference between 95/6. I'd do the swap. If there is a difference, it wouldn't be hard to fix.
