New engine swap, no throttle response.
Old Mar 26, 2013 | 12:24 AM
bigTEE56's Avatar
bigTEE56
Original owner 1994 F150 xlt, reg cab, 5.0L, 4x4, 4R70W(rebuilt by Level 10 w/torque converter), all mods meet CARB smog laws(except Crane 1.7 roller rockers), Powerdyne Supercharger, BBK Throttle body, Heddman shorty hedders, MSD Coil, HV oil pump, Cloyes HD roller timing chain. 137,000 hard miles. New engine 02/19/2013.
I'd like to thank everyone in advance for any help you can give me.
I finally put a new crate motor I'd been dragging around with me since 1996. Long story. I had previously posted concerns about using the new motors cam since it was an HO motor. I bought and installed a new truck cam factory specs. I did my due diligence when swapping motor. Since new crate motor had sat so long I replaced all seals, gaskets except head gaskets. Installed new cam and HD roller chain and sprockets. Rebuilt fuel injectors and repaired engine wiring loom. Replaced all sensors and senders, except Knock sensor. I rebuilt my blower(powerdyne). Re-installed everything and it went like clockwork. New O2 sensor and CAT.
I had to rush near the end due to needing spinal surgery. The night before my surgery I fired the Truck up and it started OK, but no throttle response. My problem is after surgery, I need to use my daughter and son in-law as my mechanics(they try very hard, they just don't have the knowledge or experience). Their time is very limited and I must try and use them wisely. I found today where I had left some electrical connections ie. the starter relay loose. I charged the battery, still no luck.
Here are my thoughts before I go forward and welcome feedback.
1. While I have not hooked up my code reader. No codes or engine lights flashing. 2. Engine sounds like it is in safe mode, it barely responds to throttle, no tach., but I know it's not going over 1,500rpm. Than if left to idle it stalls.
Could timing be off enough to run, but not accelerate? Could I have a defective TPS(new)? Could I have not installed the TPS correctly, sadly I didn't verify it before installing Throttle Body. Can I ck timing with SPOUT connected just to be sure I'm close or does it have to be disconnected? I realize I'm answering my own questions as I ask them, however if anything jumps out as an obvious problem, PLEASE let me know. I will be starting PT for my back and really don't want to take para-transit. Any help or suggestions would be greatly appreciated.
Old Mar 26, 2013 | 01:29 AM
TexasGuy001's Avatar
TexasGuy001
The SPOUT needs to be disconnected to check timing.
If the TPS is not installed correctly, the tabs on it will not move with the throttle body. Engage the tabs of the sensor with the throttle shaft blade, then rotate it clockwise to align it with the screw holes. Not doing this, can result in high idle issues. I'm not sure if it can cause other problems.
Old Mar 26, 2013 | 08:58 AM
Conanski's Avatar
Conanski
Could be low fuel pressure, depending how long the truck has been sitting up this wouldn't be uncommon.
Old Mar 26, 2013 | 07:26 PM
bigTEE56's Avatar
bigTEE56
Thanks for the responses. I failed to mentioned I pinched the fuel hose when removing the truck. It was the supply line. I checked it for leaks and have fuel pressure gauge showing 40 psi at idle. While pressure is different from volume, when i get the rpms up a little as much as I can get, pressure stays steady.
I will have my son-In law mark the 10 degree BTC mark on the pulley and we'll ck timing w/o the SPOUT connected. I'm going to have him pull apart the TPS connector and we'll test for change in resistance when throttle is opened. I suspect that is my problem and am kicking myself for not bench testing it before installing throttle body since it's necessary to pull the throttle body to r&r the TPS. Lessons learned ...
I'll let you know the results hopefully by the end of the weekend.
Thanks!
powerstroker100
18
Nov 30, 2022 01:43 PM
aquaman
2004 - 2008 F150
Dec 14, 2015 11:33 AM
Domestic_Nuwbee
Jan 19, 2011 07:17 AM
chuckles738
Feb 3, 2003 03:11 PM
deadwood
Jun 21, 2002 08:52 PM
