wiring nightmare
Old Mar 25, 2013 | 11:00 PM
Arps 6.9's Avatar
Arps 6.9
wiring nightmare
Well when I bought I knew it had some electrical issues, but they just keep popping up. Both of these pictures are of wires(strays) that I found while removing my battery tray.
And this is one of the ground cables going to the engine. Are both of the cables supposed to go right to the block, when I moved my batteries I moved one to go directly to the frame and one directly to the block, I though I was experiencing some bad ground situations.
That is what was left of one ground on the block. My problems have been, but are not limited to: fuel gauge worked, kinda, then stopped, seemed to be a connection, and I just got the wiring diagram for the fuel system, lights being dim, expecially parking lights being weird, sometimes the bright indicator will randomly go off and on, and just a mess in general, and help to what those wires might go to would be very helpful! Austin.
Old Mar 26, 2013 | 06:45 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
what year is your truck Austin? the idi was put in trucks for 11 (10.5 anyway) years and 3 generations.
Old Mar 26, 2013 | 06:49 PM
Arps 6.9's Avatar
Arps 6.9
Yeah I forgot to add that part, the truck is an '87, xl, no power anything, no air, no cruise control plain jane. These wires were found over the passenger wheel well.
Old Mar 26, 2013 | 08:39 PM
Chevy_Eater's Avatar
Chevy_Eater
Those non-factory wires might have gone to aftermarket alarm, horn, fog lights or just straight hot leads to stereo equipment.
It does sound like you have some ground issues. I've never checked to see where the factory ground cables hook up, I'll have to look in a bit.
Can't hurt to put a block to frame and fame to body ground(s) on it, then you'll have all your bases covered.
Old Mar 26, 2013 | 08:49 PM
Chevy_Eater
Okay, I just checked. Assuming my truck is anatomically correct, (could be a dangerous assumption here), both of the ground cables go from the batteries to the block.
Old Mar 26, 2013 | 09:01 PM
Phy's Avatar
Phy
Yes, both the battery negative cables should go to the block. There should be a ground strap from the engine to the cab (on the passenger side firewall on my '94), and a ground from the engine to the frame.
You can't have too many grounds...
Old Mar 26, 2013 | 10:07 PM
Arps 6.9's Avatar
Arps 6.9
The blue wire and red wires I know what they do, I am more concerned about the wires you see that just end. I moved one cable to the frame, and one is on the block, just to better ground the frame.
Old Mar 26, 2013 | 11:24 PM
kobaltblue's Avatar
kobaltblue
The batterys work together and HAVE to both be on the block,then one 6 gauge from the block to the frame,And one 10 gauge to the body to the negitive battery on both batterys and another to the cab...A diesel sucks a lot of volts on start up, And if you have an auto tranny the computer and tranny need good grounds the computer alone has 3 grounds.
Old Mar 26, 2013 | 11:28 PM
Arps 6.9's Avatar
Arps 6.9
Well I won't have to worry about a computer for a tranny until the torqshift goes in, but the two to the block is what I was looking for, thanks! Anybody see those other two wires? The one comes from the harness by the passenger headlight, shouldn't be to hard to find in a truck that hasn't been murdered electrically!
Old Mar 27, 2013 | 09:29 AM
farmert's Avatar
farmert
Tha pic of the broken cable looks pretty small to me. It should be at least a 00 size. And as stated above, both grounds attach to the block.
Old Apr 1, 2013 | 02:47 PM
Arps 6.9's Avatar
Arps 6.9
So here is more parts to the puzzle, this cluster escaped the restoration...
That group is right by my fsv, my gauge does not work, and I have never had a front tank until now so I really don't know if the selector works because I'm scared to switch it in fear it wont switch back. The yellow wire with blue trace is what we hooked up to the sender, with the other wire grounded to the frame. This worked for a while and no longer does, but I thought the sender possibly went bad. Help please! I cannot find a diagram or anything to help.
Old Apr 1, 2013 | 02:52 PM
RA31925's Avatar
RA31925
Ew, a fuse on the negative wire... bad practice.
Old Apr 1, 2013 | 04:08 PM
Chevy_Eater
Is that large shield it goes into your battery cable? On mine that's all that's there. If that wire is just tapped into the battery cable then someone was using it for a hot to something. Eliminate it.
That one's interesting, I cannot find anything like it on my truck. It looks like two wires going to a plug, two wires from the plug to another plug, then one wire out of the plug. The only thing similar on mine is a two wire into one plug then coming out one and grounding at the voltage regulator. But there's only one plug and all the wires are black, yours look green.
You say those wires are right by your FSV, but are they the wires to it? Meaning there is nothing hooked up to the valve? Or are these extra wires that happen to be next to a hooked up FSV?
Old Apr 1, 2013 | 04:15 PM
Chevy_Eater
Here's the two into one that I have, (underlined in red), it ends at a terminal connector attached to the mounting screw of the regulator.
But it doesn't match what you are showing:
Old Apr 1, 2013 | 10:23 PM
Arps 6.9's Avatar
Arps 6.9
In the first picture that large loom of wires goes to the solenoid and into the headlights, that wire with the plug has the ford emblem stamped on it, as does the other plug in the second picture, I do not see that anything does not work, and even grounded the first one out, and changed nothing that I could notice. On the last picture, those wires just come out by the fsv, there are still the six, or so, wires coming out of the selector into the loom and towards the front, that's why I'm so confused, the PO has the tail lights, signals and everything to the back re wired, but I didn't get any power from those wires while testing lights. I wonder if any of these wires were related to the truck and its previous life as a grass fire rescue truck? Some kind of prep package???
Turbo Dog
Aug 3, 2019 07:18 PM
Magnum3672
16
Jul 9, 2019 09:07 AM
papabear1941
1947 and Older Ford Trucks
Apr 6, 2019 10:30 AM
Ford Road
Aug 28, 2017 10:44 PM
mrpatrick150
May 7, 2011 04:21 PM
