f-150 lift question.
Received 3,099 Likes
on
one of the local kids stopped by with his "new" truck
96 F-150 4X4 shortbed.
it has a skyjacker lift on it, and a 3 inch body lift. 35X14.5X15 micky thompson tires.
i have a few questions for you F-150 guys.
my recommendations so far:
the body lift is going.
the front bumper is getting trimmed.
the tires are going for a set of 34X11.5 X15's.
i have a question on the lift. it seems to me like the radius arms are 2 inches too short. what do you think?
the springs should be straight up and down, rite? these are kicked back around 2 inches.
the shocks should not be touching the sway bar links, rite? if i move the axle forward 2 inches, they will clear, rite?
on edit:
just thinking about this, is it possible the radius arm drop brackets were put on the wrong sides?
it seems like they are facing back and if flipped to the other side they would face forward, moving the axle forward.
on edit:
on
but i know nothing about coil spring trucks, so that is the reason for asking.
Tom,
Move radius drop brackets forward. Use front bottom frame hole in rear hole on the bracket n drill new ones.
Move sway bar mount forward.
And swap the end links side to side n flip upside down so not drop brackets needed on the sway bar mounts.
And like said, I think the front shocks could go in the trash.
on
