View Poll Results: Where Should The Turn Signals Be Placed?
On the cowl, as pictured
37.93%
On the top of the fenders as seen on many trucks this vintage
20.69%
Raised slightly off the front bumper
41.38%
Voters: 29. You may not vote on this poll
Where Do I Put the Turn Signals?
When I got this '49 F4, it had the turn signals on the cowl as pictured. I've only seen one other truck with the turn signals in this location and I have seen pictures of another. All three have been Monkey Face trucks.
I kinda like them on the cowl as different.
My truck also has holes on the fender tops where I guess some kind of lights were placed at one time.
So it is time to decide which holes to fill and which holes will hold the turn signals.
My third option is to weld up all four holes and place the signals on the bumper.
Of course, the truck will have rear turn signals and stop lights.
The truck is being built as a driver.
What do you guys think?
I like them on the cowl, personally. I think they're safer and less prone to damage than on the fender tops. Not in the way when working under the hood, either. Less wire to run and more convenient, too. A 4th option would be to convert the park lamps to dual filament bulbs for a park/turn function, or just use the single filament for turn signal and ax the park light function. Not have an auxiliary lamp altogether. Decisions, decisions.
Well, I voted for the bumper. When I saw the picture with them on the cowl, I didn't really like it. But as I look at it more, I'm not sure. It's kind of growing on me to have them on the cowl, it is unique.
I'm not fond of the lights on the bumper.
Very nice looking truck, by the way. What are your plans for it?
The truck is currently getting an engine transplant that includes a .70 ratio OD transmission and 4.10 gear final drive. It will run 33 inch tires front and rear. My plan is to have a stock appearing driver capable of keeping up with traffic.
Most all suspension, brake work, etc has been completed.
I voted for the bumper for practical and not aesthetic reasons. The reason being, you know when you have your signal on, but they're more visible to others on all sides when they're out in front. For example... you're at a 4-way stop and another vehicle is stopped on your right. You're turning left (will be in front of them after the turn). They can't see your left turn signal on the cowl and probably not on the fender.
Just my opinion...
Just my opinion...
I know its not a 49, but I moved my turn signals from the fender mount down to the bumper on my 54. Here is why - both lights can be seen when looking at the front. The reason that is important is because in limited visibility situation on coming drivers have a point of reference to line up on. If they are mounted on the cowl for example, if someone is at a sharp angle they may only see one of the cowl lights but not know if its the right or left side of the vehicle. Think of it like you are in a fog and see only one light. With both lights visible on the bumper your mind gets a better picture. I know most people don't drive their classics in adverse weather or at night but safety and cool looks are important. The same lighting effect happens on trailers from the rear. When the lights are mounted directly on the rear you have a reference point. When they are mounted further in, like on most boat trailers, it's harder to see both sides and know which light you see.
Also, its easy to remove the lights from the bumper if you don't like them, with the cowl, you would have to patch in a hole and fix it. Whatever you do, enjoy your truck.
