I think iv got a case of the death wobble!?!?!?
Guys (and girls) i think iv got a case of the death wobble.i looked on here to see if someone else might have had the same or at least remotely the same issue but i couldn't find anything.
The trucks an 83 F250 on 33 12.5s and lifted 6 inches the seering is all stock except tie rod ends. I replaced those last summer.
If not that, jack it up and check for slack in bearings,etc on each wheel....
That would be a couple of places to start...Trav...
Its like driving a 2-ton shopping cart with a bad wheel. Whole truck front end gets into a harmonic that will make you feel like you are in a paint shaker.
I had this happen to me last year, twice. When I asked around what might be the issue - Ball Joints, Steering Linkage, Bushings, Bearings, etc. I was told that it could be any one, combination or all contributing.
I started initially with the ball joints, but as I got into it found out how far deteriorated and worn things like my steering rag joint, beam and radius arm bushings, and everything else was. Ultimately I ended up replacing:
Steering Shaft (new borgeson - well worth the $$)
Steering Linkage
Ball Joints
Axel and front prop shaft u-joints
Beam pivot bushings
Radius Arm bushings
Radiator and all four cab mounts
Motor mounts
Coil spring isolator
Axle / Hub Bearings
Hub Locks (found both to be broken)
It was amazing how marshmallow soft all the rubber bushings and mounts were. Replacing them was a pain in the a$$, but well worth it. The steering went from downright sloppy to almost responsive.
Steering Linkage
Ball Joints
Beam pivot bushings
Radius Arm bushings
Motor mounts
Axle / Hub Bearings
I had that with my '58 F-100, it turned out to be insufficient caster in the front end. If you lifted it without using different radius arms (rear of the IFS) then you probably have either insufficient or negative caster in your front end.
Since yours has leaf spring IFS, the caster is set with shims on the springs, camber is done with eccentrics on the upper ball joints.
According to AllData, on the F-250 leaf spring TTB, the caster is done with wedge shims on the springs.
I still hold that if he lifted it 6" without changing the geometry of the front suspension, he will have a caster issue. I fixed my '58 by "cheating" as i had gone from the original Mileage Maker 223 to a '57 Thunderbird Special 312 with a T85 overdrive 3 speed. I bought a set of 1/2 length helper springs and installed them on the rear portion of the front springs. Caster issue solved! The truck drove great after that.
