Expectations of my V-10 ??? and Noises under load
So I apologize now if this post is a little unorganized and long winded. I tried to put enough information in it so that you guys might be able to help me out.
The back story is the wife and I decided we wanted to buy a truck and camper last year. After reading the reviews on sites such as this one, we decided that the ford v-10 would suit our needs just right. We ended up buying a 2001 F-250 CC 4x4 automatic with 3.73 gears(68,000 miles when we purchased) and a 2008 30ft Sunset Creek camp trailer as a package deal last July. The truck has a cold air intake, modified y pipe, flowmaster 50 series exhaust, 285*70*17 tires and a 5 star tune.
I love the truck but am trying to figure out if it is running correctly or if my expectations of how the truck should tow the trailer (approx. 9,000 lbs loaded) were too high. And maybe it’s a combination of the two. I figure that there is enough collective knowledge around here that you guys can set me straight.
I have 2 concerns that may be related but would like some wisdom from the group.
1. When I get into the throttle and have a load on I get what I would describe as pinging. It sounds like a coffee can with nuts and bolts in it on a paint shaker. When this happens the truck does not seem to run any different but just makes a lot of extra noise. This noise only occurs when the truck is towing and only when going up a hill. Unloaded or loaded in the flats I cannot recreate the noise. Seems to be the worst at about 3700 rpms and trying to accelerate.
After countless searches and hours of reading on this forum I assumed it was detonation and started through the checklist of potential fixes.
I have run higher octane fuel- no difference
Retarted the timing with my 5 star tuner 2 degrees- no difference
Returned programming to stock- No difference
Replaced the fuel filter- it was dirty but still no difference
Cleaned the MAF
Cleaned the air filter
Changed spark plugs with new motorcrafts- old plugs looked good
Cleaned the throttle body
Ran Seafoam through multiple tanks of gas
After doing all of these things and not seeing any results I figured it was beyond my mechanical ability and broke down and took it to a reputable mechanic that works on a lot of ford v-10’s. They ran the truck through the ringer checking O2 sensors, MAF readings, fuel pressure while towing a skidster and could not find a mechanical reason for the truck to be making this noise. They tell me that they ran one of the fleet trucks on the same route they ran mine and it made the same noise so that must just be the way they are. I didn’t really like that response so I took it directly to Ford to see if they could update the PCM and maybe it was a computer issue. Ford looked the truck over and told me they couldn’t find an issue and they couldn’t reflash the PCM as there isn’t an updated program for my truck. This too seems a little off. While talking to the Service Manager he suggested that my issue must just be a bad Cat and I should take it to an exhaust shop to have it tested. Well I did that today and the Cat passed. Now I am just at a loss for what the issue could be. Maybe it truly is just the way this truck is… I don’t know what else to do.
2. I was expecting more performance out of this truck when pulling my camp trailer than what I am getting. Where I live there is a hill that’s 6-7% grade on my way to most of the spots we like to camp. When I start up the hill I manually shift the truck into 2<sup>nd</sup> and wind it up. Try to run in the 4500 rpm heading up. The hill is only a few mile pull but even getting a run at and keeping the go pedal to the floor we hit the top at 3000 rpms or less and doing about 45-50mph and losing steam. I know that I have the 3.73 gears and slightly larger than stock tires (285*70*17) don’t help my cause but still thought that I should at least be able to hold my momentum going over this hill. I have researched swapping gears but due to my issues mentioned above I can’t justify investing in new gears until I can stop the obnoxious noise when under a load.
Does anyone have any suggestions of something I might have forgotten to check that might eliminate my Pingging? Are my expectations to high on how this truck would handle a 9,000 trailer? And/Or issue number 1 potentially causing issue number 2?
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <woNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:EnableOpenTypeKerning/> <wontFlipMirrorIndents/> <w:OverrideTableStyleHps/> </w:Compatibility> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="--"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" DefUnhideWhenUsed="true" DefSemiHidden="true" DefQFormat="false" DefPriority="99" LatentStyleCount="267"> <w:LsdException Locked="false" Priority="0" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Normal"/> <w:LsdException Locked="false" Priority="9" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="heading 1"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 2"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 3"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 4"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 5"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 6"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 7"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 8"/> <w:LsdException Locked="false" Priority="9" QFormat="true" Name="heading 9"/> <w:LsdException Locked="false" Priority="39" Name="toc 1"/> <w:LsdException Locked="false" Priority="39" Name="toc 2"/> <w:LsdException Locked="false" Priority="39" Name="toc 3"/> <w:LsdException Locked="false" Priority="39" Name="toc 4"/> <w:LsdException Locked="false" Priority="39" Name="toc 5"/> <w:LsdException Locked="false" Priority="39" Name="toc 6"/> <w:LsdException Locked="false" Priority="39" Name="toc 7"/> <w:LsdException Locked="false" Priority="39" Name="toc 8"/> <w:LsdException Locked="false" Priority="39" Name="toc 9"/> <w:LsdException Locked="false" Priority="35" QFormat="true" Name="caption"/> <w:LsdException Locked="false" Priority="10" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Title"/> <w:LsdException Locked="false" Priority="1" Name="Default Paragraph Font"/> <w:LsdException Locked="false" Priority="11" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtitle"/> <w:LsdException Locked="false" Priority="22" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Strong"/> <w:LsdException Locked="false" Priority="20" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Emphasis"/> <w:LsdException Locked="false" Priority="59" SemiHidden="false" UnhideWhenUsed="false" Name="Table Grid"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Placeholder Text"/> <w:LsdException Locked="false" Priority="1" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="No Spacing"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 1"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 1"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 1"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 1"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 1"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 1"/> <w:LsdException Locked="false" UnhideWhenUsed="false" Name="Revision"/> <w:LsdException Locked="false" Priority="34" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="List Paragraph"/> <w:LsdException Locked="false" Priority="29" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Quote"/> <w:LsdException Locked="false" Priority="30" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Quote"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 1"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 1"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 1"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 1"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 1"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 1"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 1"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 1"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 2"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 2"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 2"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 2"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 2"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 2"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 2"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 2"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 2"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 2"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 2"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 2"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 2"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 2"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 3"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 3"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 3"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 3"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 3"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 3"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 3"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 3"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 3"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 3"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 3"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 3"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 3"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 3"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 4"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 4"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 4"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 4"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 4"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 4"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 4"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 4"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 4"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 4"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 4"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 4"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 4"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 4"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 5"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 5"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 5"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 5"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 5"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 5"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 5"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 5"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 5"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 5"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 5"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 5"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 5"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 5"/> <w:LsdException Locked="false" Priority="60" SemiHidden="false" UnhideWhenUsed="false" Name="Light Shading Accent 6"/> <w:LsdException Locked="false" Priority="61" SemiHidden="false" UnhideWhenUsed="false" Name="Light List Accent 6"/> <w:LsdException Locked="false" Priority="62" SemiHidden="false" UnhideWhenUsed="false" Name="Light Grid Accent 6"/> <w:LsdException Locked="false" Priority="63" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 1 Accent 6"/> <w:LsdException Locked="false" Priority="64" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Shading 2 Accent 6"/> <w:LsdException Locked="false" Priority="65" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 1 Accent 6"/> <w:LsdException Locked="false" Priority="66" SemiHidden="false" UnhideWhenUsed="false" Name="Medium List 2 Accent 6"/> <w:LsdException Locked="false" Priority="67" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 1 Accent 6"/> <w:LsdException Locked="false" Priority="68" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 2 Accent 6"/> <w:LsdException Locked="false" Priority="69" SemiHidden="false" UnhideWhenUsed="false" Name="Medium Grid 3 Accent 6"/> <w:LsdException Locked="false" Priority="70" SemiHidden="false" UnhideWhenUsed="false" Name="Dark List Accent 6"/> <w:LsdException Locked="false" Priority="71" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Shading Accent 6"/> <w:LsdException Locked="false" Priority="72" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful List Accent 6"/> <w:LsdException Locked="false" Priority="73" SemiHidden="false" UnhideWhenUsed="false" Name="Colorful Grid Accent 6"/> <w:LsdException Locked="false" Priority="19" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Emphasis"/> <w:LsdException Locked="false" Priority="21" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Emphasis"/> <w:LsdException Locked="false" Priority="31" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Subtle Reference"/> <w:LsdException Locked="false" Priority="32" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Intense Reference"/> <w:LsdException Locked="false" Priority="33" SemiHidden="false" UnhideWhenUsed="false" QFormat="true" Name="Book Title"/> <w:LsdException Locked="false" Priority="37" Name="Bibliography"/> <w:LsdException Locked="false" Priority="39" QFormat="true" Name="TOC Heading"/> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority9; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} </style> <![endif]-->
Cleaned the MAF
I cant help with the noise but can tell you that you're not alone!
When I traded into mine (a year newer, similar mileage, and crazy enough, the same mods) I had a toyhauler in the same weight range as yours. I traded the weekend before a camping trip so I pulled with it right after I bought it, up a hill just like you describe, and yes, I was disappointed, 2nd gear, 35ish...
I read a thread that said something like "3.73s are ok to 7-8k lbs, above needs 4.30 or better", which I have to agree with, I pulled the same hill with a smaller (6k) camper after a header install, and although i couldn't carry 3rd, I was able to accelerate in 2nd all the way up it. Mine seems to like the 4k+ rpm territory, Im still getting used to that.
With all that said, earlier today I ordered some 4.30s to go along with the LS unit that I originally intended on installing. I know the feeling of not wanting to throw good money down a hole with possibly no return, but I really think 4.10s should have been the base gear for us, and the 3.73s are the killer for heavier loads. I'll find out in a couple weeks.
Your lack of power on hills is the 3.73 gears and larger tires. The ping can be a lot of things one of them may be your modified Y pipe, the 2V V10 is very picky when it comes to the Y pipe believe me I know. I'm not sure what you are using for gas but I have had a lot of trouble with fuel when traveling in our area and west to the coast. One thing to try is run a few tanks of 10% ethanol through the truck and see if that will make a difference, it does make a difference when it comes to preignition or ping if that's what you have.
My truck rarely pings but in certain areas of the country it will, Alaska being the worst and most of the west coast a close second, Florida is about as bad as the west coast. You also have to be careful in the higher altitudes because they sell 85 octane (altitude blend) instead of 87 octane and it will ping when we get to lower altitudes every time.
Denny
Denny
Thanks for the responses guys.
gfl and pappy, a gear set is the 2nd thing on my list of upgrades for this truck. It was number 1 until I got more concered about my engine noise. I have already been to a local drive train shop to price them out. He has done several v-10's and doesn't recommend putting anything less than 4.56's in them if you are going to spend the money to do it.
gfl, in your post you mentioned that you are putting a limited slip in when you change your gears? The drive train shop recommended that i do the same but i guess i don't understand why. What is the advantage to limited slip?
Pappy, I have the 5 star tuner for the truck and that alone has made a drastic difference in how the transmission functions. I dont search for gears any more. Does the shift kit you are talking about help that much more? Guess maybe i should do some more research on shift kits so that i can understand exactly what they do.
RV Puller, thanks for the idea. I had not considered that the Y pipe could be causing this noise. I might have to start looking at salvage yards to see if i can find a stock Y pipe for a reasonable price.
Denny
After the header install i found my rear tire spinning pretty easily, and putting the camper back into storage i found myself spinning tires on flat ground just moving my camper around. Some of the places i like to go, traction is a must to get your rig back out and on the road. If you're mostly on pavement, its a judgement call.
I'm cursed with not being able to leave well enough alone with anything, so don't do anything i'm doing thinking its absolutely neccesary
on
I think the Transgo Tugger kit is about $150 or less and replaces the plastic valves with metal and also the new plate lets you upgrade the shift firmness. I used the middle one when I had it installed on my Bronco and also on my 2002 F-350, and it's just about right. You can get the kits at www.suncoastconverters.com along with some other good tranny goodies.
I just got mine back today with just the rear done, LS and 4.30s (waiting for some parts for the front). I was afraid when making my choice on gears that 4.30 might be too low, but i can see a case be made for 4.56 depending on where you're driving.
If it helps anyone, with stock tires now in 3rd 65=3k rpm , and in o/d 75=2.4kish and the motor really doesn't feel like its screaming at those rpms. I'll know a little more about towing with it here in a couple weeks.
and the LS works great , they set me up with a 10.25 setup, which apparently interchanges ok and is less expensive than the 10.5 version.
F250 Harmonic/wind noise
Been meaning to do this for a month. The aggravating harmonic wind noise on my 2011 F-250 came and went with the wind direction and intensity. It turned out to be (FROM THE FACTORY) halfway up on each a pillar and in the bottom of the windshield there was no sealant at all causing the trim gasket to vibrate left or right side depending on the direction. Trouble shoot by using a blow gun at the seal while feeling for air movement in the cab along the garnish molding. I had the windshield re-sealed, prayers answered, very quiet ride now.
Yes I am referring to Horseshoe Bend Hill. That thing just kills me. I was really hoping when i bought the truck that it would handle that hill a little better. The tuner sure helped but if I really want to pull it well I am sure that I will have to change the gears.
I'm curious...which tune are you running? And what gasoline (brand, and octane)? Are you running 10% ethanol, or 100% petro?
I have not yet hauled my camper and ATVs up that grade yet. And although my total load will be quite a bit less than your weight, I'm rather preparing myself for a gear swap. I haven't decided between 4.30 or 4.56.
If/When you swap gears, I would VERY much like to hear your impressions with your load.
Hey guys, Excursions driver here with the same motor and trans as you guys pulling a 9k+ ToyHauler. My factory gears were 3.73 and it would drop out of OD towing on the slightest grade, really killing my towing MPGs and just generally bugging me. I also heard some pinging under load but not too bad. This is my rig.
I upgraded to 4.88 gears (with a rear locker), no tunes yet but a purchase from 5 Star is next on the list. With the 3.73's I had towed around PA and all through New England suffering on every hill. After the gear change we traveled through VA,WV,TN and KY, plenty of mountains there and it was a completely different truck. It would still drop out of OD on the big stuff but it now would pull most grades in OD.
Two weeks ago I installed a set of the Banks headers and Y pipe and set off on a 1900 mile trip, 1500 miles pulling the TH. I've towed the same route for the past 3 years and have gotten a low tank MPG of 6.00 and a high of 7.63 with an average of 7.07MPG on the towing legs of the trips. This year with the new gears and the Banks headers I got a low of 6.90 and a high of 9.08 and an average of 8.09MPG. Thats a 14.4% increased in MPG on the same rig over the same route. And the EX did NOT drop out of OD once while at cruising speed over the entire trip, granted this route is not in the mountains but in the past it always dropped down a gear in the rolling hills of VA and MD.
Also I did not hear any pinging on this trip. These V-10s love deeper gears and the headers offer a little more grunt in mid to high RPMs where these tow rigs earn their keep.
WE3ZS: That's awesome feedback. It sounds like your EX is primarily your tow rig, just like my F350 is for us. I'm just curious, though, how your empty (non-towing) mileage with 4.88 compares to your old 3.73 setup?
Btw...based on my experience with the 5star tuner, I think your grin will only get bigger when you pull the trigger on one for your EX.
