shaking in overdrive?
Hi i have a 91 300-6 with an e40d transmission..... i have noticed a shaking in overdrive that seems to be possibly tranny related or TQ converter? it does it with mostly anything below 1400 rpms anything over that it seems fine and when i turn off OD it stops the shaking
any ideas? thanks
any ideas? thanks
on
Don't go guessing at the problem, pull the codes and know if there are any problems related to powertrain control, if there isn't then your problem is vacuum, fuel, or spark related.
BTW.. what gearing does you truck have? If it's typical for an I6 truck you shouldn't be using OD at anything less than 60mph anyway.
That's far from screaming in an I6, if it was a cummins 5.9 then yes, but not for a gasser. My I6 with the M5OD runs ~1450rpms at 60mph, and I use OD at 35mpg as itkeeps my RPMS under 1k in town, saves a LOT of fuel as I idle around town. I also have the 2.73 rear gears.
How long ago did you do a good tune up? It could be almost anything, but I'd start at the ignition system and work my way around to the transmission.
yeah when i said screaming i was somewhat exaggerating but my point being there would be no reason to turn od off when crusing at 60 mph unless your aiming to suck down a lot of fuel... when i cruise at 55 (majority of my driving) i turn 1400-1500 rpm which is about the best gas mileage i can prob get........
i was also leaning to tranny because (sometimes) the shaking will stop when letting off the gas
and what do you mean by ignition system?
on
No I wasn't suggesting you turn off OD when cruising I meant just getting up to speed. My thought on the shaking is that it could be a lean stumble caused by a leaking thermactor(air injection) system or crossfiring plug wires, this will be most obvious when the engine is under maximum load which is lugging in overdrive.
lock up convertor is slipping(at that slow of rpm). Try some additive to fix it. If not, do a full fluid/filter change and put some Mercon 5 in it. Should clear it up with some driving. What happens is the fluid breaks down, the clutches won't release smoothly, thus "chattering". Once you get some new fluid in it and drive it, it will start to smooth out.
My '95/302 truck did it when I bought it. Fluid fixed it. My '89 just started to act strange when I bought it. Did a service on it and has been fine. Both trucks were at the 90K mile mark.
Check fluid and see if it is getting old(turning dark red).
Thoth88
08-08-2017 05:42 AM
