Auxillary Diesel Fuel Tank
Check out this system.
It's what I'm going to get what I get my truck and I have been looking around for a while now.
They are available from 40 up to 87 gallons and have an automatic fill system available if you want it also.
The Fuel Box | Auxiliary Fuel Tanks | Zylstra Automotive
That's the same idea behind my transfer flow tank. Fills the main tank as I drive, really nice to have. When towing I can drive over 700 miles without fueling!
http://www.transferflow.com/fuel-tanks/in-bed
Looking at a Titan 50 Gallon Tank
The 26 gallon stock tank (about 22-23 gallon usable) just does not cut it towing, so a Titan 50 gallon tank is high on my list. I passed a sign last fall going into the northern reaches of the Gila National Forest in Southwestern New Mexico .... "No Gas Food Or Lodging next 121 Miles" and this was 50 miles AFTER the last gas station. Now it would be my luck that I would get in 100-110 miles and the road would be blocked and I would have to come back out!!!
I just had a Transfer Flow 50 gallon installed in the new truck. I had one in the old 2006 and wouldn't be without one. We pull a 35' 5th wheel camper and not having to stop for fuel with the trailer on makes it worth the investment just for that.
I did have a problem with the new control unit. Transfer Flow sent a new one second day air. Super customer service!!
I have a chassis cab and it has 40 gallon tank. I added RDS 60 gallon, Airtex pump, AutoMeter fuel gauge on dash, Wix fuel filter/water separator and 12 volt fuel shutoff. It's hooked to upfitter #3 and it works great. 1,000 mile fuel range when towing the 34' 5th wheel, but I refuel twice on my 1,800 mile trip as they are the two cheapest fuel stops on the trip. This is the second truck I've had this arrangement on, and won't be the last. That is as long as I'm pulling a 5th wheel from Kansas to California.
Good luck with your choice!!!
Jim
Jim
In-Bed Fuel Tanks - Transfer Flow, Inc. - Aftermarket Fuel Tank Systems
Thanks!
Jim
Jim
Where did you ,mount the tank?
New to the forum and looking to extend my fuel range also because I haul a 5th.
Due to having a short bed and a roll bak bed cover I'm short on space. The only tank I can use is a rectangular box small enough to fit under the bed cover near the cab. Problem is I can't find a transfer tank that will fit, only auxiliary tanks. Can I use an auxiliary tank to pump from instead of an transfer tank? I don't want to go to the trouble and expense of piping the auxiliary tank to the on board fuel system. I think it would work with a DC pump but I'm no mechanic and don't want to waste my time and more importantly my money!
Thanks for any help and advice.
I carry three 5 gallon diesel fuel jugs when I travel with my 5er. Although I have the 38 gallon tank with the dually, I still like to have a little leeway when it comes to fueling up. This little $20 transfer pump works great and is powered by two D-cell batteries. You can get them at Home Depot and other fine hardware stores like Ace. Just a thought.
Buy Trademark Tools Battery Operated Liquid Transfer Siphon Pump & More | drugstore.com
Transfer Tank
I have a 2011 F-250 SD short bed too, I pull a 36' Carriage 5th wheel, I have a Pullrite Superglide hitch, installed in my bed. I wanted a regular transfer tank with tool box but would not fit, I removed my tool box and installed a 37 gal fuel tank, I opted for making it a gravity flow. I had it painted to match truck, It looks great and will install this weekend.
Transfer Flow 37 gallon rank
