Banks Torque Tube headers V-10 install w/pics
#46
Just a thought but are the studs breaking because the stud is stuck in the block or because the nut is rusted to the stud? From the pics it looks like the top of the stud is designed in such a way that it could have a wrench put on it. Meaning dont try to loosen the nut but grab the top,of the stud and loosen it with the nut untouched?
#48
I pulled all 18 of my surviving studs/nuts out whole without issue using a socket on the rusty nuts, my two broken ones were broken long before I lifted the hood.
#49
For the dremel you will need Diamond Head Bit, Burr, Stank, and then Tungsten Carbine cutting an coring bits, and also 3/4 boxes of metal cuttig wheels.
Sorry so long and this was probably more than you were wanting to knowl
My lession learned
If you are going to drill a pilot into a stud it must be centered, that is tough working close to the head. Take you time and work your way up sizes, don't get impatient and try to use an easy out too soon. Some will work but only the square ones, never use those or any bit other than Colbat, and the Diamond, Carbide or Tungston bit on the dremel. If an easy out or a drill bit breaks into the stud your day just got really bad. Took $299 in Diamond head attachments and 3 days to get the easy outs and broken drill bits
#50
That sounds just brutal. What an awful way to spend a few weeks!
I have a 6.0l diesel so I'm assuming that my situation would be different, if I ever decided to do something like this. Its way, way down on the list but I like to learn from other poor guys who have been through all the pain! Thanks for sharing yours.
#52
#53
#54
I have large hands, and had no issues what so ever with my Hedman headers. It's not bad at all if you just have at it
#55
#57
The Banks headers came with several heat shields, plenty of folks have installed them with only the supplied shields and have no problems. I added the extra insulation and foil shielding just because I had it on hand and I was in the area around the new tubes. If you can't over-do it, it aint worth doing!
#60
Great write up. I read this entire thread 3x and each time I get a little more brave and think of trying to tackle this project on my own also. I hope that feeling passes soon.
Which torque tubes are for the Excursions?
This is from Banks site;
Application---------------------------------------Year Range----------- Part #
TorqueTube system----------------------------------1999-04------------49133
Ford 6.8L Trk, W/egr Late Cat
Emissions compliant: CARB E.O. D-161-76
TorqueTube system----------------------------------1999-04------------49136
Ford 6.8L Trk, W/egr Erly Cat
TorqueTube system----------------------------------1999-04------------49138
Ford 6.8L Trk No-Egr, Late Cat
