FICM Relay Location
Old 02-20-2017, 09:56 PM
hink10's Avatar
hink10
hink10 is offline
FICM Relay Location
I have a 2005 6.0 and a FICM tuner from PHP. I need to remove the FICM relay so I don't fry injector 1 (I think that what it is). Anyway, I've done a lot of reading and can't seem to figure out which relay it is. The instructions say the relay closest to the passenger front, but also say almost always grey. So, The grey relay is passenger toward firewall. The directions also say that the injectors will not buzz if removed. I took each out and still had injector buzz. Tried again tonight, truck is hot, just been driven. I pulled the grey relay and turned key to on. Buzzed for just a second then stopped but did the same for the other relay and same when put back in. Can anyone confirm that it's the grey replay in the photo? I have to leave town Wednesday and can't afford to mess up!
Thanks!
Steve
Old 02-20-2017, 11:13 PM
erikkloss's Avatar
erikkloss
erikkloss is offline
This link is to a picture of the battery junction box. The FICM power relay is shown in the lower right corner of this diagram: http://www.revbase.com/BBBMotor/Wd/D...dPdf?id=111513
Old 02-20-2017, 11:25 PM
hink10's Avatar
hink10
hink10 is offline
Thanks, I have it figured out with Razzi's help, it's the gray one in the photo. The diagram doesn't resemble any fuse/relay box in my truck but thanks!
Old 02-21-2017, 04:56 AM
Patriotic Rottweiler's Avatar
Patriotic Rottweiler is offline
I had the same issue with my ficm tuner from Innovative Diesel. I had to update the software before doing the first tune from Superchips.
I ended up having to go with the Inductive Heating tune on mine as the performance tune made the truck run really rough.
99FORD EXPY.
01-17-2013 06:50 AM
V10man
Electrical Systems/Wiring
12-01-2012 11:27 AM
Shattered
09-21-2012 11:04 AM
stroke-of-luck00
10-31-2008 09:16 PM
Quick Reply: FICM Relay Location
