Oil Leak
Old Mar 18, 2013 | 04:07 PM
pin8246's Avatar
pin8246
Oil Leak
This should be pretty simple for someone here that knows what there called. I have an oil leak, its the drain plug, so I need a new one most likely.
Question.
A while back I read a post on here, someone changed the drain plug to one that is kind of like a valve type. Basically it takes the place of the drain plug, then you twist the valve to drain it. I can not find that link on here now. Don't know if I'm not using the correct search terms of what. Does anyone have a link to that thread, or the company website that makes or sells them?
Thanks.
Old Mar 18, 2013 | 04:17 PM
Jmatthews's Avatar
Jmatthews
is a BAAAD MAN
Fumento valve.
Old Mar 18, 2013 | 04:23 PM
pin8246's Avatar
pin8246
Thank you. Any downside to these?
Old Mar 18, 2013 | 04:48 PM
binuya's Avatar
binuya
I have a Fumoto valve. I like being able to easily switch it open to drain the oil, and it makes it real easy to grab a sample to send off for OA. It drains slower than a standard plug, but I use that time to change the filter out. Some might say it hangs too low, but there's plenty of other things in the chassis that hang lower. I figure that the chances are pretty remote that something solid enough will strike it. Definitely not enough for me to worry about. In my opinion it's a great mod.
Old Mar 18, 2013 | 09:15 PM
MTDewX's Avatar
MTDewX
x2 on the samples if you want or choose to do that.
it is nice whent taking the plug out and not risking dropping it in the pan or getting dirtier than usual.
I have used them on several rigs. no issues so far.
Old Mar 18, 2013 | 11:01 PM
crop harvester's Avatar
crop harvester
I had a drain plug weeping very slow & changed copper washer from ford, problem solved.I only replace plug when threads start to wear,the Fumoto sounds nice.
Old Mar 18, 2013 | 11:08 PM
BigAlsPSD's Avatar
BigAlsPSD
Clay sells them if you need a source still.
Riffraff Diesel: Fumoto Quick Drain Valve
Riffraff Diesel: Fumoto Quick Drain Valve W/ Nipple
Old Mar 19, 2013 | 02:58 AM
Justin@DP-Tuner's Avatar
Justin@DP-Tuner
PREMIUM SPONSOR
The Fumoto valves are nice for sure, but in my experience they drain extremely slow. I just use a standard drain plug now so I do not have to wait forever to change the oil.
__________________
Justin
Like us on Facebook!
www.dp-tuner.com
Old Mar 19, 2013 | 06:26 AM
pin8246's Avatar
pin8246
Originally Posted by BigAlsPSD
Didnt know he sold them. When I get close to my next oil change ill give him a call.
And the slow I dont think will bother me, never in no real hurry around here anyways.
Bohen
6.7L Power Stroke Diesel
54
Feb 21, 2020 09:40 AM
Robby Nash
Nov 19, 2012 01:18 PM
Cpljdrose
Feb 22, 2008 06:35 PM
stevenn1
Dec 14, 2006 06:07 PM
krcobra
Nov 25, 2006 04:08 PM
