I have a 2008 with the spartan tuner on it and running the 310 tune and when I started racing and I put it to the floor and I started good and the it seamed like that motor started to die dose any one know what this is and how to fix it? Thanks for any advice
I'd be more apt to take a look at your boost pressures, egts, etc. You might be defueling.
If I recall, according to Spartan, the factory intake system is perfectly fine until you tune to the point of changing injectors, turbos, etc.
Bear in mind that if you are "racing" on your stock drive train, your 310 HP tune will help you find all the weak links in it sooner rather than later.
Besides that, why are you here asking that question? Spartan has a website and is way more capable of providing info regarding their system then most anyone here will be.
Sounds like defueling to me. I have an H&S but I imagine there is a way to set the refueling parameters on the Spartan, maybe one is set too low. I once had my tranny temp set at 130 degrees, oops.
I dont believe the 310 tune has any defuel safety parameters and the end user cannot adjust them as of yet. The OP poster is likely dropping rail pressure due to the LP pump not being able to keep up.
