Leaking fuel tank
Leaking fuel tank
And the smallest hole can leak like a siv.
I lost 1/2 tank in 30 miles on a dirt road from a hole rubbed in by a top strip being gone. The hole was so small i had to shake the tank for it to suck out to find the hole. Never did see the actual hole, but i puttied over a 2"x2" area to be sure it was plugged.
Leaking tank
Forgot to mention this is '84 f250 w/ 6.9.
I was inside writing this and my son said to look at truck. I looked out window and spotted a buzzard sitting on limb of large white oak, 25 feet over top of truck. Another landed further out the limb and they both sat looking up and down. I called myself barely alive because this truck has been through a lot, but I think I can scare the scavengers off a little longer with some helpful advice from anyone with experience. And I don't mean advice on taking care of the vultures!!
I extracted these two posts from Alan's thread and created a new one with them.
It's not nice to hijack someone else's thread with your own problems, please don't do that.
If you can get all the crap off. Jiggle the tank to slosh the fuel. You will see a wet spot pop up or maybe even the hole. Jb weld makes a gas tank repair putty. I worked it up and ground it in the area with my thumb. It was good to go in an hour or so.
If you have a hole or a area getting soft a new tank can be bought for about 120 givw or take a few.
A new tank would be best. Where in NC? Check out NPD near Charlotte or our other sponsors.
NPD - Restoring American History | Mustang Parts | Camaro Parts | Chevelle Parts | Ford Truck Parts | T-Bird Parts | Firebird Parts
I am about an hour northeast of Charlotte. Statesville is 30 miles due west from me on I-40. I checked NPD and it showed no match. I will do some other searching with local connections. Thanks for the lead. I purchased a new radiator thru a store that a body shop employee referred me to and was given a great price. Maybe I will have similar luck with a little digging. I wonder if there is any difference in a diesel tank than a gas tank?
Continuing to evaluate the leak. I removed the bed and found what looks like a breather line coming from top of tank. The plastic end was completely covered with sludge. When I pulled the cap off the line it made a sucking noise making me believe this was not clear to vent like it should. Since fuel is leaking from tank, this would create a vacuum if air is not coming in.
I have removed the fuel line cap with the two lines and gage terminal (sending unit/pickup), drained 15 gallons from the tank, and dropped the tank. I was able to get all nuts loose using an impact wrench and vice grips on rounded nuts. I did not know these tanks were aluminum. I am in the process of cleaning tank to see if there are any visible signs of punctures, cracks or cap seal problems. The seal on the sending unit (looks like an o-ring) does not look good and makes me wonder if leak is occurring here.
