1984 F250 4X4 very clean and straight
Year: 1984
Make: Ford
Model: F-350
Price: $6000
Mileage: 170000
Color: Blue
Private or Dealer Listing: Private Listing
Location (State): OH
Transmission: Automatic
Drivetrain: 4WD & AWD
Color: Blue
Engine: 351W
Dana 60 rear axle 3.55 gears
Dana 50 front axle 3.55 gears
4X4
Holley 650 4 Barrel Carb
33' All Terrains 90% tread
12.5x16.5 Mickey Thompson rims
About two months ago, the truck got two new cab corners, new drivers side floor board and rocker, new doors, new front fenders, southern bed, rear fender replaced, and gone through front to back eliminating any rust. The truck was then painted with base coat/Clear coat. This vas very expensive and done right.
New Parts:
Windshield
Mirrors
Center Caps
Starter
Starter Relay
Voltage Regulator
Alternator
Battery
Radiator
blower motor
wiper fluid motor
turn signal and brake wiring
Carb Rebuild
Brake Lines
Master Cylinder
Exhaust Manifolds
Dual Flowmaster Mufflers
Fuel Tank
Spark Plugs
Tailgate
Pioneer Radio
Alpine Speakers
Rear Air Shocks
Front Shocks
The rear drum brakes have been replaced by disc brakes for better stopping in wet conditions. The motor has edelbrock valve covers and air filter.
Pictures: http://s1185.beta.photobucket.com/us...3/library/F250
I'm Located in Canton, OH.
Does the truck still have a parking brake with the disc swap? Was a proportioning valve changed/added?
Thats a very sharp looking truck. What color is the paint?
Thank you for the replies. I decided I was going to do the swap without the parking brake with future plans of installing a Mico Lever Lock parking brake when I had the time to do the proportioning valve. Which also answers your second question, no it has no proportioning valve yet. The paint is true blue metallic. I believe the code is L2 and it was used on 2005-2008 F250s from the factory.
Creamsicle88
01-03-2017 10:27 AM
KsHighboy
22
04-16-2016 11:53 AM
Biggone
10-12-2014 12:22 PM
crazed87bronco
12-03-2010 09:17 AM
HazeyDavey302
03-24-2006 11:14 AM
