Anyone with actual experience with electric fans on a 300?
My mechanical fan is really loud and seems like it would be a lot for this engine to turn. I feel like electric fans would be the way to go and it would be a pretty basic install. I did a search but couldn't find anything other than mechanical vs electric debates.
I know that electric fans need a thermostat with a sensor I believe, the gas mileage will increase because the motor isn't spinning the mechanical so an increase in power also arises. the only problem that I see is is that the electrical fan kicks on and off and you never know when it will turn on... I've had the same thoughts but for my 5.8
on
all items sold at delta current controls.
this is for the diesel,but there's some stuff posted here to help you guys also im sure;
https://www.ford-trucks.com/forums/1...ar-diesel.html
with my control unit,i also have an adjustment **** in the cab mounted on my gauge pod.along with this adjuster,is also an indicator light,showing me just what the fans are doing.
Don Vito
29
01-20-2018 03:38 PM
NICODEMUS
06-05-2005 11:29 PM
