Fuel economy of non-turbo 7.3 IDI?
Also on the topic of oil, ALL oils have to pass a benchmark, often times what you have to look for is what they ADD to the oil, not what they leave out Penzoil for instance..*shudders*
Fuel economy though, being SWB and OD id say 20 is not unreasonable if everything is in good shape, especially with 3.55s
Delo 400 15/40 with 2 quarts mobile 1, 0-40 M full synthetic, it the only oil that Mercedes will use in there diesel engine cars, it meets all the European oil standards, and mobile 1 601 power stroke filter, its bigger, and has duel filtration 5 micron and 16 micron. 14-16 mpg, the girls pull horses at 60mph. 4.10 rear, e4od, low stall converter.
About 15 mpg in my 88 F-250 7.3/5-speed/4.10/4x4 reg cab. That's doing 70-75 mph on highway 75% of the miles and 25% city. I have approx 32 inch tall all-terrain tires. The 4x4 will not get as good mpg as a 2wd, and bigger off-road type tires also will hurt mpg some. I could probably get better mpg if I drove slower.
been averaging 12.7 lately with the 92, very slowly, steadily getting worse. Swapped pump and injectors off an engine that ran great, no difference. Currently timed at 8* BTDC via pulse adapter. Not sure if i want to compression test it or not lol. Granted, most all the miles are 75-80mph or stop / go city driving, but used to get 14.5
1989 F-450 11ft Flatbed
This is my first truck. I have a 1989 F350 with a non-turbo 7.3 IDI motor in it, with about 162,000 miles. It has a 5-speed manual transmission, it's 4x4 and it's a single cab long bed I think. I recently put 285/75r16s mounted on 16x8 wheels on it. I have two 15 gallon tanks, as well. I'm not sure about the gears, though. I'm not going to be towing anything, just driving it. I won't be going on the highway much of ever, either. Just around here on country roads and all that. Can anybody give me an estimate of the fuel mileage I should expect with this truck? The guy who sold it to me said around 16 mpg, but I wanna be sure. Thanks!
Thanks for the advice,
Emily Shelton
Received 3,102 Likes
on
I am looking to buy an 89' F-450 11ft flatbed 7.3L 5 speed manual w/ regular cab. I don't know the rear-end size or the tire size. Does anyone know the range for the MPG on this truck? It will be a daily driver and to pull my 23' bumper pull RV.
Emily Shelton
Emily Shelton
unfortunately that truck is going to be a fuel hog. there were two gear ratio options on the F-SuperDuty, 4.63 and 5.13, 4.63 was kind of rare.
on
Emily Shelton
Emily Shelton
Just to chime in here, I have a 85 F-250HD with 4.10 rear end gears and a 6.9 paired with a C6 transmission. I get 12 on a good day, kills the pocket but I love the truck. If I could find a cheaper way to get more economy out of it I would it in a heartbeat. Anybody know why I cant get these numbers that sound like a pipe dream to me? Oh and I should add it's a reg cab long bed 4x4.
on
Maybe you IP timing ain't right too....
12 MPG is really low that's more like what a 460 Gashog gets. Som Ting Wong
I will add that 4X4 always got worse mileage than the RWD and dually is less economical too.
#28
on
not really wolfie.
4.10 gears C6 trans and 40 cetane fuel is only going to give up around 12-14 mpg.
back in the good old days when we had 60+ cetane fuel my 4X4 with C6 and 4.10 gears could see 20 -22 regularly if i was granny drive on the interstate. but not these days with the watered down crap they are calling diesel fuel.
#29
not really wolfie.
I just recently checked my fuel cetane and I'm at 49-52 in my tank right now.. it's Valero Diesel and it's over a year old.... I will be filling up again here pretty soon as I need to take the truck for State inspection.
