Is a 12'' rim too wide?
Depends on the wheel spacing. Most likely it will rub. I run 16x10's (w/ -25mm or 1" offset) with 35's and a level lift and it barely rubs the backside of the leaf spring under full turn. I actually rubbed worse with the factory 7.5" wide wheels. If it doesn't rub, that means you will have even more hanging out the front side...
If it were me... I wouldn't run a 12" wide rim on a 12.5" tire. I think the tires would wear funny and you wouldn't have much sidewall to protect your rims. I think 10" wide rims would be good for a 12.5" wide tire. John2001 can get away with a 12" wide rim because his tires are 15.5" wide.
I had a set of 10" wide rims with 14.5" wide tires and they looked bubbly for lack of a better term. I agree a 10" wide rim should do you fine
EDIT: I also have a set of factory rims with 315/75 or 34.5x12.32" mounted on them there 16" rims and they look great
