Procomp 22210 vs. 22410 springs?
#46
#47
And they'll clear 35's with room to flex no problem.
#48
#49
#50
Hey, I've been reading this thread and I see you are online. I am in the same situation with saggy springs. I have drop shackles on the front and I'm still 2 inches lower than the rear.
Just wondering how the 4 inch superlifts went? Was it too high?
I actually just ordered the Pro Comp 2 inch springs yesterday and then I found this thread. I figure since I'm so saggy I will likely see about 3 or so inches with the new 2 inch lift springs. I may install the drop shackles again to get even more out of the 2 inch pro comps.
#54
One thing I may have going for me is the fact the truck has 259,000 miles. So my stock 4 inch F350 rear blocks along with the 2 inch pro comps might look okay. Thought being that the rear springs probably have some sag too. I was afraid to go with 4 inch because if it was too high I would have to spend more money to raise the back more. It sucks having sagging springs because you don't really know what 2 inch lift springs will do. Depends how far from stock I am sagging! I may update this with my findings after install just for someone else like me searching this topic. Thanks for replying.
#56
Got my 22210's installed and here is my experience.
With stock springs I was at least 4 to 5 inches lower in the front. I put drop down shackles on stock springs and gained about 2 inches. I was still however 2 to 3 inches lower.
Installed 22210's and WITHOUT the drop shackles (stock shackles reinstalled) I was at the same place. about 2 Inches lower than the rear. With the drop shackles now back on I am finally level. If I had gone with the 4 inch spring I would not have to use the drop shackles. I would say the 22210's are not a 2 inch lift on a 7.3 diesel. I do think they would level an F250 due to the shorter rear blocks. In my experience F350 owners should get the 4 inch 22410. I will attempt pics now. Never done it....
#57
This is stock springs, Stock shackles.
This is Pro Comp 22210 with stock shackles, before the settled in. Might have settled about 1/2 an inch after 1 week
<a href="http://s1134.photobucket.com/user/cdorsey50stang/media/Mobile%20Uploads/20140228_085119.jpg.html" target="_blank"><img src="http://i1134.photobucket.com/albums/m615/cdorsey50stang/Mobile%20Uploads/20140228_085119.jpg" border="0" alt=" photo 20140228_085119.jpg"/></a>
This is Pro Comp 22210 WITH 2 inch leveling drop down shackles.
#59
315/75/16's installed on stock rims, NO rubbing at all. Not even close.
<a href="http://s1134.photobucket.com/user/cdorsey50stang/media/Mobile%20Uploads/20140319_153331.jpg.html" target="_blank"><img src="http://i1134.photobucket.com/albums/m615/cdorsey50stang/Mobile%20Uploads/20140319_153331.jpg" border="0" alt=" photo 20140319_153331.jpg"/></a>
#60
78F250400
22
01-10-2014 06:54 AM
ColdForge
03-15-2011 09:43 AM
