Procomp 22210 vs. 22410 springs?
#31
I'm running the 22210 with 255/85r16 (34") and if i drove street only 35's would fit okish. But any amount of axle movement and 35's would hit, i DONT off road my truck thats why i have the 77 F150 but when i go hunting, etc and flex her out the front tires almost hit the front fender in the rear now, a 35 would fit but when i do flex her out the 35 would smash my fender all up. Now a x code and then a level kit and 35 maybe but someone who runs this needs to post a picture of this setup flexed out......
#32
funny how i have to use Summit website to find info on ProComps lifts? but here you go
4" kit contents
2004 FORD F 350 SUPER DUTY Pro Comp Suspension Lift Kits K4018B - SummitRacing.com
2" kit contents
2004 FORD F 350 SUPER DUTY Pro Comp Level Lift Suspension System Kits K4012 - SummitRacing.com
4" kit contents
2" kit contents
#34
they are 16x10 mickey thompson classic II's powdercoated black, with OE black centercaps. i'm using open-ended lugnuts on all lugs, then i have an OE lugnut on every other stud (on top of the aftermarket nuts) for the center caps to clip to.
#35
same here. i think your lift/tire size combo would look great with a 10" wide rim. just mini-pack leveled mine (i say leveled, but i think i have saggy stock spring syndrome like Miles) with 285's on 16x10's:
love the '05 front end too! definitely on my list of things to do.
#38
#40
#42
I just don't want it to sag out quick. If I went with a BDS for another $200 I won't have that problem but damn its alot of money
Basically my problem is if I do springs I'm gonna say "wow wish I went with a 4" lift" and if I do a 4" lift it's gonna be "wow that was a waste of money"
So that's where I'm at...
#44
#45
Yeah I mean I'd like to do 35s but either way I need tires soon. And I'm buying 17x9s regardless, so I'm thinking of just doing x codes and maybe 34s or so. And then in a few years I can do a full 4" lift. Just don't want to spend $1200 right now really, and don't want to just buy stock size tires
