Fuel Economy?
on
There's something seriously wrong with an I6 truck that only gets 10mpg, in general you would have to be using it for snow plowing or something like that to do that bad.
Does the truck get the same fuel milage on both tanks? It should so if you're not that would indicate a fuel transfer problem.
As indicated check codes and fix anything that comes up, and if the O2 sensor hasn't been replaced in the last 60k put one of those in it too.
31's would make the OD ratio even "Shallow-er"...Meaning the truck has to kick down to passing gears pretty much any time you get on an incline..Of any sort.
As I said earlier; If you've not re-calibrated your speedometer, etc for the 31" tires...Your mpg readings won't be accurate.
Still not biting man..
dont blame you most people dont believe me until they see me fill up and run the numbers
My 94' 4X4 averages 15-17 MPG.
I'm a grandpa and I drive like it too.
Bob
FORDSIX PERFORMANCE • View topic - Coast-to-Coast: Mega-MPG
And this one...
FORDSIX PERFORMANCE • View topic - Bumper mod, spare relocate, etc., = 4mpg bump
But I also don't get why people often suggest a mileage improvement by going from a 3.08 to 3.55. Clearly you're going to turn more RPM doing that. If you're in 5th and need some more gear, why not just downshift to 4th, no? Otherwise, drive it like a Peterbilt for best mileage.
Maybe he re-calibrated and went too far the other way.
If you're looking for someone to call out, try taking a look at this thread...
And this one...
And this one...
Either he doesn't know how to calculate MPG, or he's done something MAJOR and isn't telling... Like a Cumming 4bt swap possibly...
on
you swap to the 3.55's for increased in hauling/towing grunt power,or to compensate for larger tires.economy suffers by doing this swap.how much it suffers depends on how fast you normally drive.
some claim the lower gearing will be better for city stop and go economy,but i didn't see any increase when i did the swap.thankfully since i drive slow/no hwy,economy didn't go down either,but most people here don't drive as slow as i do im sure lol.so no doubt as general rule,3.08's can only be beat by that silly rare 2.73 option or whatever it is.-iv never seen a f150 with this gearing personally.im sure that's getting way out of hand.a slush puppy 55mph + hwy cruiser only type truck.
#29
Monahan77
09-07-2015 09:45 AM
