3rd door stuck
My passenger 3rd door was stuck, I removed the panels and there are 2 cables, 1 cable had become un anchored, for the lack of the technical term, I was able to use a Wire Tie and re anchor it.
As far as I know the cable is the only way to open the door, you will probably need to replace them.
3rd door stuck driver's side - how to open stuck door
I got it - maybe keep this in how to? After removing the door panels and the two cables I found that the end of the cables had deteriorated to nothing. The top latch was holding my door shut. Under the weather stripping you can see the mechanism. The big latch has a spring next to it and there is an L shaped metal piece. Get a double wired clothes hanger and push on the little spring that is next to the latch - you have to push down, and the latch will open. I can email a pic or try this F150online Forums - R8rvectors's Album: Rear Door Upper Latch - Picture
GavinL
11-21-2018 12:51 PM
Polkster
11-16-2013 08:49 PM
