6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 PATS SYSTEM FAIL.
Old 03-11-2013, 07:42 PM
PDS
PDS is offline
PDS is starting off with a positive reputation.
No I have not. I do not know which ones to check and what they should be reading.
Old 03-11-2013, 08:14 PM
cheezit's Avatar
cheezit
cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
there are only 2 each is 120 ohms. if the i/c and pcm are on line you should have 60 ohms. the other is in the pcm
you check them at the dlc.
look at the no communication pinpoint test.it covers it pretty well.
whats the network test say about the pcm?
remeber just cause it lights up doesnt mean it works
Old 03-15-2013, 01:59 PM
PDS
PDS is offline
I replaced the I/C and it worked truck runs great BUT I bought a used cluster and now miles are wrong. about 100,000 wrong. any place that anyone knows where to send it to match old milage up
Old 03-15-2013, 04:55 PM
cheezit's Avatar
cheezit
cheezit is offline
good luck on that. you best best is to have it done threw a certified shop. also you should by law (iirc) have a door sticker that says the odo has been changed otherwise its basicly odo fraud
Old 03-15-2013, 05:21 PM
PDS
PDS is offline
ya have the sticker to put on door. But I want my the miles off my old odo. and talked to ford shop and they said the only way to change that is to order new i/c then they program the miles off of old one.
didn't know of place that will fix my old i/c that way I have my right milage
banshee_man_96
11-22-2018 07:20 AM
jas88
1997-2006 Expedition & Navigator
26
06-17-2017 09:00 PM
BeachEx
05-21-2014 05:29 AM
No-Tyme
2004 - 2008 F150
21
12-06-2010 04:12 PM
cobrarep
08-03-2008 01:13 PM
Quick Reply: 6.4 PATS SYSTEM FAIL.
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
