1960 Super Duty Crew Cab build thread - Page 21 - Ford Truck Enthusiasts Forums
  #301
Old 12-07-2017, 12:32 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4 78_f800crewcab4x4 is online now
78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold78_f800crewcab4x4 is a splendid one to behold
Just did a complete tear-down. Currently bare frame. Going to finish the cab and bed indoors. Will send off the frame to powdercoater at some point.
  #302
Old 12-07-2017, 05:32 PM
1985 Bronco's Avatar
1985 Bronco 1985 Bronco is offline
1985 Bronco is starting off with a positive reputation.
Wow! What brought this on? Thought you were just gonna drive it as is?
  #303
Old 12-11-2017, 09:45 PM
Need to work on this thing in the light. Winter darkness has haulted the progress. Widow makers removed, Springs modded and de-arch, Frame rivets being removed, holes welded, mods finished and then off to powder coater along with the rest...
Cramming it in there until I can sort through the mess.
  #304
Old 12-12-2017, 12:30 PM
Martin Torres's Avatar
Martin Torres Martin Torres is online now
Martin Torres is starting off with a positive reputation.
[QUOTE=78_f800crewcab4x4;17453544]Bed floor out. Bed Front panel out:
I’m planning on raising my bed floor 3” and want to save the middle ribbed portion. Other than cutting through what looks like 600 spot welds on the edges, was it secured anywhere else?
  #305
Old 12-12-2017, 06:43 PM
Just the sides and to the top of the cross members. There were two center thin cross members that you could keep attached to the floor pan and raise with it since they don’t go all the way across.
  #306
Old 12-12-2017, 07:16 PM
Quote:
Originally Posted by 78_f800crewcab4x4 View Post
Just the sides and to the top of the cross members. There were two center thin cross members that you could keep attached to the floor pan and raise with it since they donít go all the way across.
Thanks much.
F600 Super Bronco build. Death Metal recommendations. Recipes. 78_f800crewcab4x4 1973 - 1979 F-100 & Larger F-Series Trucks 281 12-06-2017 03:52 AM
Lowering my 78' F150 and Crown Vic suspension swap davewild 1973 - 1979 F-100 & Larger F-Series Trucks 327 09-16-2017 12:53 AM
2017 Super Duty - Pictures ZAR2USA 2017+ Super Duty 84 09-06-2016 02:55 PM
2004 F250 Lariat V10 chefcollins1 Vehicles for Sale 0 05-03-2016 10:16 PM
Question: is this a long bed truck or a short bed? demonkiller3418 1967 - 1972 F-100 & Larger F-Series Trucks 3 02-28-2016 01:43 PM
Tags
1960, crewcab, dually, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
