1960 Super Duty Crew Cab build thread
  #256
Old 10-13-2016, 05:02 PM
78_f800crewcab4x4's Avatar
78_f800crewcab4x4
78_f800crewcab4x4 is offline
Surfacing welds on the oem in-bed tire carrier to fill the heavy pits at the bottom:
Donor inner and outer cab corners will need a few pits welded:
  #257
Old 10-14-2016, 11:53 PM
1985 Bronco's Avatar
1985 Bronco
1985 Bronco is offline
Making good progress on this!
  #258
Old 10-24-2016, 12:51 AM
78_f800crewcab4x4
Finishing up the welds and smoothing joint:
Completed:
Complete:
  #259
Old 10-24-2016, 09:28 AM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
Looks like you've got plenty of room between the cab and the box for something. Custom slip tank perhaps?
The following users liked this post:
  #260
Old 10-24-2016, 06:04 PM
78_f800crewcab4x4
Exhaust stack for a diesel. Maybe a small tool box.
  #261
Old 10-25-2016, 04:26 PM
Aaron-71's Avatar
Aaron-71
Aaron-71 is offline
That gets a big stamp of approval from several users.
What diesel motor are you dreaming of? Cummins? Powerstroke?
  #262
Old 11-06-2016, 06:16 PM
78_f800crewcab4x4
Thanks. Probably the 8.3 Cummins or whatever I can find complete with an air brake compressor and power steering pump. Probably will buy a complete truck for a donor.
Other side being welded:
Tailgate chain bolts cut down with ss cap nut like original:
  #263
Old 11-08-2016, 09:22 PM
78_f800crewcab4x4
Bed extensions done:
  #264
Old 11-08-2016, 10:43 PM
1985 Bronco
Very nice! What's your plans for the roof?
  #265
Old 11-09-2016, 12:21 PM
78_f800crewcab4x4
Going to finish the rocker panels and floor bracing next. Once cab structure is sound, will be welding on the C-series roof donor section from earlier in the thread. Still bouncing around between different fab projects around the truck.
  #266
Old 11-11-2016, 06:13 PM
78_f800crewcab4x4
Got stuff back from Van Nuys plating:
Mirror brackets done:
Chromed speaker grille:
Excellent shop. Flawless work. Recommend.
  #267
Old 11-12-2016, 02:34 AM
oldbleu's Avatar
oldbleu
oldbleu is offline
The quality of the chrome looks excellent!
Any concern about the gare you will get reflecting off that speaker grill?
  #268
Old 11-14-2016, 06:04 PM
78_f800crewcab4x4
Rear fender seam fully welded and finished. A lot of hammer/dolly work.
  #269
Old 11-23-2016, 01:12 AM
78_f800crewcab4x4
Ongoing metal work:
Back up weld with custom copper spoon, weld, hammer or punch weld from behind, smooth, hammer/dolly, smooth.
  #270
Old 01-05-2017, 05:49 PM
78_f800crewcab4x4
Oem spare bracket repaired, ready for powdercoat along with another I acquired:
Factory tow hooks for front and rear awaiting chrome along with the oem turn signal housings:
The 70's running boards need to be re-shaped at the corner to fit the fender shape better, here is a graft from the old steps, and the filler plate the newer steps don't have:
Quick Reply: 1960 Super Duty Crew Cab build thread
