What to look for in a 93 F150
#31
Also how do you tighten the right side of the dashboards? Mine bounces up and down on the highway from vibration.
#32
#33
2 ways of fixing it:
1: Find an OEM bracing kit for ~$25
or
2: Go to the hardware store and get an L bracket for .40c and use self tapping screws to install it.
Either way, it's right behind the P/S kick panel. Pull it straight out, and look in the lower corner and you'll see it.
On the dash pad, to remove the glove compartment, unlatch it as normal, then look at the bottom. There's 2 "Clips" that hold it onto the main dash. Gently press the "Fingers" back and it'll be ready to slide up and out.
#34
I saw a bed at hollands Junkyard in Billerica, MA (I live right next to lowell in Tewksbury) that i might go see how much they want becasue my bed is shot lol. Also it has a second fuel door for maybe a later mod. I also got two new A-pillar trim pieces as mine were broken and rattling and a new dash pad which i cant figure out how to install.
Here's a good write up on how to replace the dash pad:
Dash pad replacement, 92-96 - FSB Forums
#35
Ah! I was wondering where that nice dash pad went. I was just at Holland's the other day (needed a new water outlet)! Glad to hear that a fellow FTE'er got it.
It's the main right support brace is broken (Common issue, as it's made of plastic)
or
or
Also fixed the speedometer in my truck it was fuse 8 lol i thought the only fuse involved with that was fuse 18 so i only checked one. Oh well you live and learn, at least i have a tach now i guess.
#36
Just noticed that i have a light one. I think its the safety restraint light or airbag light, its the one with the little guy in a chair and an airbag coming out at him lol. It flashes once then waits 3 seconds then flashes twice and ideas what that it? Also is there any way to replace the dome light with a different one like in the newer super duty's? i burned my hand on it yesterday after having it on for a few min.
#37
I'm not sure what the flash once, wait, flash twice code is. I do know that most airbag light issues seem to be related to the clock-spring being bad. Perhaps someone who's been through this can provide more insight.
[EDIT]
I found this thread on airbag issues:
https://www.ford-trucks.com/forums/1...-flashing.html
#38
My headliner has been hanging down so last week I ordered a Suede headliner kit in black and some black Colorbond paint (paint number 324) and im gonna start blacking out the Interior. I plan to paint the outside black down the road. With all the rust and body work I plan to fix the entire truck minus the cab will need to be painted again. Also just got a new ignition cylinder and door locks so i have two sets of matching keys and door locks with a key now. I had no key for the door locks when i purchased the truck.... I'm gonna be busy next weekend with both trucks lol.
#39
Over the weekend I gave her a little bit of a face lift, I got a black billet grille, smoked headlights, and black headlight bezels. I replaced the orange marker lights with LED's and i got a set of 55w 6000k HID's. Inside i recovered the headliner in black suede, and painted the trim all black I just have to replace the carpet and paint the dash now. I did not have enough time to et it dry so it got slightly beat up while re installing it. This weekend I plan on taking the scratched pieces out and giving them one more coat and letting them dry completely. Also added a taurus dome light since the stock one burned me a few times and got some LED's in there as well.
Rodier
07-21-2014 06:54 AM
hbkirishwarrior
15
09-09-2011 12:13 AM
427 fordman
07-15-2009 11:10 PM
ChaoticBaz
Paint & Bodywork
08-31-2007 11:37 AM
