I know it has to be on here somewhere but I can't find it.
I am looking for a post on a basic swap of a 302 non roller and a c4 into a bone stock 67f100 with a 300 and three one the tree. I need a list of things I need to get the engine and trans in and settled. I am mostly concerned with the engine mounts and tranny cross member.
I am going with a b&m shifter so trans shifting is no problem.
Also wondering if the driveshaft length is something that I can find from another setup or need one custom built. This truck is going to be a cruiser, maybe 300-325 HP.
You will need the engine perches (302) from a 68-79 Ford pickup, move the existing cross member as needed. Resize your current ds or go to a one piece cut to fit.
Question, If you are going to a 302/5.0 why not use an AOD for better fuel mileage?
So the only thing I need is the engine perches. Thanks, could I find new perches so I don't have to go on a wild goose hunt? If so where? And I just want a c4 due to simplicity.
If you use an AOD transmission Jus be really good at adjusting that kick down cable because it will not shift over 1st and will burn it in less then 3 minutes...( I worked at a trans place)
True with the Cleveland fun to drive at 8 mpg it was a little expensive.Not the greatest pictures look in my gallery I have the mounts pictured on my truck
