1955 F250 (Emma) Build Thread
#33
#34
Hi Ben,
Thanks, and no thats just the primer on the valve covers. They will likely end end up being silver. I believe the original color is argent but I'm not going to go to far out of my way to locate it. All the rest of the engine parts are painted and ready for install. Waiting on gaskets. Hopefully next weekend I can think about putting the engine back on the frame.
#38
And frame horn install complete. Could have done a bit more grinding but oh well...good enough for the girl I go out with.
https://www.ford-trucks.com/forums/p...ctureid=139999
#39
So I've extended my working season on the truck by moving it in the garage. This is will be a huge PITA with my daily driver once it gets cold and starts snowing. But here is a status on my goals for this year:
1) Remove the steel bead and fabricate a temporary flat bed: Bed is removed, frame cleaned/painted and flatbed foundation bolted to frame.
2) Remove the 239 (not original) and tranny for cleaning (engine/tranny are solid): Completed
3) Rebuild Carb: Completed
4) Replace U-joints: Not needed yet
5) Rebuild front brakes and new brake lines (rear lines replaced with the rear brake rebuild): Completed, new drums, wheel cylinders, shoes and lines.
6) Dual stage master cylinder upgrade (manual): Not Completed. Going to run the single MC a bit longer.
7) Headers or original exhaust (one of the areas I’ll be looking to discuss): Almost completed, went with stock exhaust. Hope to pic up a crossover tube tomorrow. Rest of exhaust system sandblasted and POR15 applied
8) Fabricate frame adapter for a Front bumper (I found detailed drawings of that part of the frame on FTE a few years back): Completed, got a pair from an FTE member.
9) New gas tank: Almost completed, put a clear coat on it this evening and plan to install this weekend.
In addition to these things I pulled the PO wiring and will custom make the harness/electrical upgrades myself (PO already converted to 12V)...Its been a busy year. Hope to actually start the engine again within the next two weeks.
#41
#44
#45
Thanks. I've never did notice the cab mount issue while driving but this creaky ole gal had so many issues I'm not surprised. I found it once I had the front body panels off and could see where someone had tried to weld/fix the cracked mount in place on the forward side. Once the gas tank came out I found that it was broke on that side as well. Basically not supporting anything. I'm anxious for spring to get her back on the road. I also decided just to buy the EZ 12 circuit wire harness rather than build my own. Temps are starting to get in the upper 30's in the daytime so I'll be heading back out to work on her.
Cheers
Cheers
