Help can not remove HUB
Old Mar 2, 2013 | 05:21 PM
mrslatham's Avatar
mrslatham
Unhappy Help can not remove HUB
I can not remove my locking hub on the driver side of my 1994 F150 it broke a wrench trying to remove it and its suppose to be easy can someone please help me.
Old Mar 2, 2013 | 06:11 PM
kermmydog's Avatar
kermmydog
My 95 uses an allen wrench, They should just unscrew, unless the hub has been in water or a real wet climate then rust plays into it. my experience is cheap allen wrench's can break.
Craig
Old Mar 2, 2013 | 11:23 PM
Encho's Avatar
Encho
The Southernmost Mod
Check the link for Front End Rebuild in my signature, it has detailed info and pictures on the subject. At which step did you get stuck? just removing the cap?. If the bolts in the cap are too tight, get a set of allen screwdriver tips and a socket wrench, then insert the right tip on a 1/4 socket and use the wrench to apply more torque and release the bolt, good luck!.
Buyerz
Sep 30, 2012 10:19 PM
TennesseeMustangPerf
Dec 17, 2010 02:51 PM
caleb6.9
Apr 16, 2010 08:41 PM
oxypower
Jun 29, 2006 07:15 PM
fyrfytr
Offroad & 4x4
Jan 28, 2004 10:11 AM
