Automatic stalls while driving
Old Mar 2, 2013 | 06:23 AM
kwizman's Avatar
kwizman
I have a 1991 F250, 7.5 Automatic(i believe a E4OD) 4x4. I had the transmission rebuilt a year ago, I've recently replaced my TPS and gear position sensor.
When I hit a bump or it goes to shift it'll throw a check engine light and stall out. Sometimes it kicks right back on, others I have to roll off the road and pull the negative termial off the battery before it starts again.
I ran a the Key on test, got codes 21, 26 and 24. I ran the test with it running and got 77, 74, and 65.
I havent checked the codes when it stalls, mostly because I'm going up I-95 or I 70 in Maryland and I really want off the side of the road there. lol
Thanks for the help.
Old Mar 2, 2013 | 08:23 AM
subford's Avatar
subford
Those codes are all either from a cold engine/transmission or operator error so you have no codes.
Are you saying the engine is quitting or the transmission is going into neutral?
Old Mar 2, 2013 | 09:48 AM
kwizman's Avatar
kwizman
Engine is quitting, shutting off/stalling.
Old Mar 2, 2013 | 10:00 AM
subford's Avatar
subford
If it was only dieing after hitting a bump I would say check the wires under the EEC & fuel Pump relays sockets.
Unhooking the battery would only make the computer relearn the information sent from the sensors.
Old Mar 2, 2013 | 10:09 AM
kwizman's Avatar
kwizman
I went under the hood and checked all the connectors around the EEC, thinking it was something loose in there.
I'm certain its something computer related because of the reset temporarily solving the problems.
Old Mar 2, 2013 | 10:12 AM
subford's Avatar
subford
We have had computers on this site that would do that and when shut off for a while would let the engine restart and run again for a while and then do it again.
I think they have had bad caps in the computer. Some posters have replaced the caps for about $2.00 and that seemed to have fix it.
Old Mar 2, 2013 | 10:15 AM
kwizman's Avatar
kwizman
yea, might have to bite the bullet and replace it, last thing it can be that hasnt been replaced this year.
Old Mar 2, 2013 | 10:17 AM
subford's Avatar
subford
Just open it up and see what the caps look like. You might be able to fix it yourself.
Also re-read post #6 above as I have edited it.
djust
Nov 13, 2006 10:56 PM
BigGreenGiant
Jun 28, 2006 05:27 AM
jhnhardee
Dec 24, 2005 06:13 AM
Mike8500
Nov 29, 2005 09:13 AM
acerockola77
Dec 20, 2003 09:47 PM
