Delaware's March 2013 BS thread
#65
#66
anyone here close to seaford and has a fuel pressure tester and maybe help me trouble shoot why i cant get my motor to run? thread for what ive done and not done can be found here (ill cover fuel and any reasonable part off of the truck im parting out)
https://www.ford-trucks.com/forums/1...l#post12920599
PLEASE HELP!
PLEASE HELP!
#69
On the driverside fender is the tfi modual. Right by the firewall. under the speed control computer. Is it black or grey? what about the parts truck?
try switching the 2. Your fuel signal gets interupted by the distributer, and if you have the wrong tfi, the truck will only prime the fuel system, but not run
#71
That is the power for the distributer. It used to be on the distributer, but it got way too hot, so ford put it in a heat sink over on the fender.
Color of the tfi is important, you can not use a black one where a grey one belongs, or a grey where a black belongs.
They also have a high failure rate.
#73
#74
the one on the 350 is grey the one on the 250 is black......would it be easier if i just took off the harness on the swapped motor and put the old one on the new motor??
and if i put the black one on the green truck is their other things i have to change as i already put the original brain back on the truck....
further more does the black on belong to that distributor?
