wrench light no crank
Old Mar 1, 2013 | 07:56 AM
PlatinumPSD's Avatar
PlatinumPSD
I have a 2005 6.0 My EGR has been unpluged for some time. I pluged it back up with truck running an a few sec. later the truck dies Check Gauges Lights up on dash and no crank. Is there A fuse I could Check first?
Old Mar 1, 2013 | 08:57 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
You need to see what the codes are.... do you have any kind of code reader? Scan Gauge? A friend? It prob is NOT a fuse.
Old Mar 1, 2013 | 09:24 AM
mustang_309's Avatar
mustang_309
Is it a no crank or no start?
Old Mar 1, 2013 | 09:41 AM
dannyboy950's Avatar
dannyboy950
Agree with the codes and scan for live data. If it is indeed the wrench light the pcm may have shut it down to keep from a catastrofic engine failure.
Old Mar 1, 2013 | 09:44 AM
6.0techwannabe's Avatar
6.0techwannabe
Why would u just unplugg ur egr valve? U need to delete the cooler. Keep the valve plugged in...albeit,cleaned. Your issue could be a few things. Theres a stc fitting that needs updating if u havnt already done it. Hpop leak. Ckp and cmp could not be syncing. Ficm could be shot. A plethora of other things not to mention... Your pissin in the wind without a scanner.
Get the codes and report back soldier!
Old Mar 1, 2013 | 10:03 AM
PlatinumPSD
I picked up a cheep code reader from Autozone all it read was no link. cheep POS. It is a no crank the FICM reads 47.8 A. cleaned the EGR valve that was why I plugged it back up. Know someone with super chip 1706 would this read codes it was for a 2006 6.0 and I have A 2005. the EGR valve was unplugged becouse it was putting the truck in limp mode and a read a lot of people just unplugg them.
Old Mar 1, 2013 | 10:13 AM
PlatinumPSD
Will the EGR valve send a message to the PCM to shut off ignition switch?
Old Mar 1, 2013 | 10:16 AM
PlatinumPSD
All of these would be a no start but it would try to turn over.
Old Mar 1, 2013 | 10:23 AM
mustang_309
So if it is a no crank ( meaning the starter doesn't do anything when you turn the key to start ) if so have you tried holding the shift lever up in the park position or putting it in neutral? If it is a no start ( meaning the starter turns the engine over but she wont roar to life ) You are gonna need some gauges that read live data to point you in the right direction.
Old Mar 1, 2013 | 10:26 AM
mustang_309
Can you get the starter to turn the engine over using the method in this video?
Old Mar 1, 2013 | 10:30 AM
PlatinumPSD
will try this when i get home. TY for the tip.
Old Mar 1, 2013 | 10:35 AM
mustang_309
Anytime let us know what you come up with.
Old Mar 1, 2013 | 02:59 PM
PlatinumPSD
Jumping the starter like in the video above did work but no start. picked up superchip to read codes will update tonight.
Old Mar 1, 2013 | 03:06 PM
m-chan68's Avatar
m-chan68
The PCM is not supplying ground to the ground side of the starter relay for whatever reason. Start unplugging three-wire sensors under the hood, one at a time, until communication is restored to the PCM for the engine to resume cranking over again. I would start with the fan clutch wiring connector.
Old Mar 1, 2013 | 03:12 PM
PlatinumPSD
Where are the three sensors you are talking about?
