need help identifying this front diff Dana 60F
Old Mar 1, 2013 | 12:05 AM
walangsilbi's Avatar
walangsilbi
Hi,
I'm new here, I was hoping someone can tell me something about this Dana 60 I just bought. From my investigation, this may have come from a 1977 F250 crew cab. I need to buy brake caliper rubber boots and alum piston. The casting says Dayton. The boot has a number 69340596. The caliper casting has a number (best guess): 00710382. Please advise what part numbers i need so I can purchase brake repair kit.
TIA
Old Mar 1, 2013 | 08:09 AM
teds74ford's Avatar
teds74ford
On the tube, near the pumpkin, is the BOM. if you lightly sand or wire wheel, you should find it. That # would be really helpful for telling what exactly you have.
Old Mar 1, 2013 | 09:19 AM
spikinfool05's Avatar
spikinfool05
what size was the pan cover bolts that will help also. and does it have kingpins or ball joints.
Old Mar 1, 2013 | 10:18 AM
brian1080's Avatar
brian1080
I'm no expert, but it's a low pinion which means pre 78 correct? My friends 76 had the same axle. I also read that 76-77 had disc brakes, pre 76 had drum.
Old Mar 1, 2013 | 10:40 AM
montana_highboy's Avatar
montana_highboy
Bingo! it's a low pinion D60... open knuckle, king pin, disc brake, from a 76/77 Crewcab.
Old Mar 3, 2013 | 02:07 AM
walangsilbi
Thanks Guys! I was able to get the BOM and indeed it could be from a 77 crewcab. Now for some more questions:
Can someone share part numbers or links to EXACT item I can buy piston cups (Dayton dual pistons), repair kits? The alum piston diameter is 55.4mm.
I live overseas and don't have stores that sell these items here. So I will order them over the net and need to be precise otherwise it will be more expensive to return the item.
Also, the diff ratio is 4.10. I want to buy a 4.88. Can anyone show me links to where I can get R&P? I believe there's a standard and reverse cut. Don't know what I have/need.
TIA
Old Mar 3, 2013 | 06:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Precise: What is the Dana BOM number? / 1976: There are TWO different types of dual piston calipers, TWO different types of caliper pistons.
D6TZ-2120-A .. Dual Piston Caliper Repair Kit (1 required per side) / 1976/79 F250/350 & E250/350.
D6TZ-2194-A .. Caliper Piston-Use with Dual Piston Caliper marked: 69710332 / Obsolete
Applications: 1976 F250 2WD/4WD & F350 / 1976 E250/350.
D2TZ-2194-A .. Caliper Piston-Use with Dual Piston Caliper marked: 69710382 / Obsolete
Applications: 1972 F250 2WD & F350 w/optional dual piston caliper disc brakes / 1973/79 F250 2WD & F350 / 1976/79 F250 4WD / 1979 F350 4WD / 1976/79 E250/350 (E = Econoline).
These parts are obsolete. I'll list the sources that have them NOS (that will ship 'across the pond' to Cebu, Luzon, Mindoro, or wherever) once I know which caliper pistons you need.
1976: First year for disc brakes w/4WD. 1959/75 4WD's have drums.
Old Mar 3, 2013 | 07:45 PM
walangsilbi
Welcome to FTE
BOM is 610008-2
I measured the aluminum pistons and they are like 55.4mm. While we are at it. I am also thinking of buying a 4.88 R&P. Currently it has a 4.1 ratio. I'm not sure if i need a standard cut or reverse, thick or thin?
Thanks,
Old Mar 3, 2013 | 08:20 PM
bartn98's Avatar
bartn98
Give Randys ring and pinion a call, excellent customer service. www.ringpinion.com
mofoco1
Mar 27, 2019 08:19 AM
skobydog
Sep 3, 2018 10:43 PM
tomwerm
16
Mar 7, 2016 07:13 PM
Wayne64SS
Jun 18, 2015 11:09 AM
adam83
13
Oct 28, 2009 05:24 PM
