I need some parts!!
I need some parts!!
Hey Guys and Gals, I am in need of a few 390 parts, there are also a few parts the I'm really unsure of the technical name so I'll just explain them.
I need
Timing Cover
Valley Pan
Windage Tray
Oil Pan for a truck
Then the piece of metal that sits between the push rods and the valve springs.
Thank you, Mason
I need
Timing Cover
Valley Pan
Windage Tray
Oil Pan for a truck
Thank you, Mason
I looked for small hints Art..............
His signature line has this:
1975 F-250 Highboy 390ci
I'm guessing it's 4x4. .................................................. ...... (or it might not even be for the truck and then I'm just being a smartazz)
What's up Art, ol buddy?? You been hiding or is it just me??
The "drip rails" for the valvetrain, or "tins" by a select few.
All items should not be hard to come by. I don't have a bunch of spare parts as such(at least that I want to part with), but someone should have them from a motor they tore down/scrapped. I'll look, maybe I have a few sets of tins. Be glad to donate to a good cause.
Oil pump drive. You can buy a stock version or a nice aftermarket version.
ARP Oil Pump Driveshaft Kits 154-7902 - SummitRacing.com
Ok guys what is all needed after I have my long block.
These are the parts I have plus the ones up top
Oil Pump
Oil Sump
Windage tray
Oil Pan
Timing Cover
Drip Rails
Rocker Arm Assembly
Intake
Push Rods
Valve Cover
Carburetor
Distributor
Does that sound right. What else do I need (for parts that go INSIDE the engine)?
Oil Pump
Oil Sump
Windage tray
Oil Pan
Timing Cover
Drip Rails
Rocker Arm Assembly
Intake
Push Rods
Valve Cover
Carburetor
Distributor
Summit is where I got mine
1969 FORD F-250 PICKUP 6.4L/390 ARP Engine Bolt Kits - SummitRacing.com
