7.3 Rebuild...the beginning!
#46
Thanks Sean. It's a combination of age and pride. In my younger days I used to run from the top of the hill into the herd all excited and unfocused, trying to be everywhere......now, I survey the situation, set my sights on the goal, and walk slowly and with purpose towards my goal. Happy endings, lol. . Energy is sooooo wasted on the young.
#47
#51
Here is todays progress.............
Got the support bracket for the pickup tube so tomorrow the pan goes on. Also, should mention that one of the main purposes behind this build at 400k miles was to get rid of the PMR's. Installed Crower connecting rods in their place.
Non-EBPV Turbo Pedastel and 38R installed.
Not happy with the casting marks so I polished the tunnel as best I could using a combination of 80 and 120 flap wheels, then used my Dremel to reach in further and for finishing.
38R with Wicked Wheel 2 installed. Polished the intake side as well.
Installed the Banks 4" Power Elbow and IH Bellowed up pipes. The manifolds all the way through the turbo, through the down pipe is all ceramic coated. I wanted to keep the heat up to the turbo for effeciency, then out of the turbo down the exhaust down pipe to help keep as much heat as possible out of the engine compartment.
That's if for today....progress. Tomorrow...going to see with this sliding mechanism on the hoist if we can get the engine installed with the Turbo mounted. If not, the fact that we did the pre-fit and have everything aligned should allow quick removal and easier install if we have to remove it.
#53
#54
on
That's a Turbo Master Wastegate Controller. Got mine from Dieselsite. I had one on my stock turbo and later transfered it to the 38R. I sold it when changed out the turbine housing to a 1.15 A/R nonwastegated one. I liked the ease of adjustment and and how it kept the WG closed until its set point.
#55
#56
Off topic...
I have no idea how I got here reading your build. Maybe it was one of my searches...
But to the OP, why did you post in your chapter forum page and not in the main powerstroke forum. I'm sure lots of guys would love to see your build.
If I had not stumbled onto this build, I would never known of your project.
Back on topic, that wg controller is $180. Holy crap. Seems more than what I'd like to pay, but if it works the way you want then great. My tightened stock actuator does what I want with an acceptable amount of creep. It pegs 30psi and by the top of 3rd gear its up to 35psi. Fine by me.
My twin turbo truck has external wastegates, And is getting an electronic boost controller.
I gotta get saving for injectors... That thought just ruined my night. Oh well.
#57
Off topic...
#59
Just out of curiosity, if you are spending the money on the Crowers, why not add a girdle while you're there. The weakest point is the block. The Crowers will take a lot more stress than the PMR's or Forged rods, but the block twisting can still do some damage. Just wondering if it was something you had thought about?
