Oil leak 2005 Mariner 3.0L
This 3.0L Mariner has developed an oil leak at the rear passenger side of the engine. After cleaning up the residue and re-checking, I've determined that it is coming from somewhere on the engine block behind the alternator. I've verified that the source is not higher up, such as the cam cover, but even with the plastic side cover off and wiring pulled out of the way, I can't see exactly where it is originating.
Has anyone experienced this particular leak and/or know what the fix is? Really annoying - it drips straight down on the exhaust pipe.
Thanks for any input.
Nor would I! Mine is only up to 104K so I'd prefer to fix it if it doesn't involve major disassembly. Otherwise I might have to invent a fireproof diaper.
Thanks.
Unless there are 'plugs' where oil galleries were drilled, the only things that can leak are a porous casting, and gasketed joints of the block & head, and the block & pan, and the block and front cover. Not that many choices. I believe the use of silicone RTV is specified where the timing cover, block and oil pan intersect. Very common on FoMoCo engines, and I suspect other mfgs.
Last possibility is the separator in the 'vee' between the cylinders, but not sure how it would migrate...
Looking at a drawing of the firewall side, there is a plug with a large hex-shaped hole immediately behind the alternator, but the diameter looks too large for an oil passage.
tom
tom
I can see that plug, and also looked at the drawings in the shop manual. The plug is dry, so at the moment I'm at a loss to explain where it's coming from, unless it is the joint between the block and the "girdle". That intersection is a little oily, but it doesn't appear to be the leak source, to me.
2003 escape 3.0 Alternator area oil leak...
2003 escape 3.0 dohc 2wd
Is it possible that the alternator mount boss,furthest from the front of engine,on the block,not the bracket,was tapped (factory)into the oil passage?
i ask because I found sealant on the bolt, mounting the alternator bracket, during a head gasket,chain,oil pump replacement..
oil was leaking from that area,after startup..
Just wondering...cause it ain't coming out the timing,cover,nor the valve covers,nor the head...
maybe this warrents examination,,
Maybe this will help someone else...
Thank..
Thank..
Thanx..
Thanx..
2001ExcursionV10
12-19-2002 06:25 PM
