911- Lincoln 4.6 Oil Leak.. Please Help
I have a 2000 Town Car with a 4.6 v8.. COP just like my Modular V10..
I have a pretty major issue. I took it apart today to change the plugs out. There was no oil spots on the drive way but a minor miss has manifested and with 130k on the clock I figured it was time to change the plugs. It has consumed about 1 quart of oil every 3000 miles which is normal per the documentation I have read from ford..
Well, the motor isn't consuming oil, its leaking oil on top of the motor
Here is what I pulled out of the spark plug well
Here is a shot of the spark plug well itself
The Tube coming off of the PCV valve on the drivers side had some oil in it..
Could it be as simple as a bad PCV valve?
Is this a bad intake manifold?
Blown Head Gasket?
Help.
Blown Head Gasket?
Help.
tasboj
19
05-30-2013 07:10 PM
dean35
11-20-2005 04:41 AM
