Go Back  Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Reload this Page >
'02 7.3L with 105k miles- Newcomer looking for wisdom
Old 02-22-2013, 03:31 PM
Powerstroke_Wing
Powerstroke_Wing is offline
Powerstroke_Wing is starting off with a positive reputation.
Hey all,
My dad recently handed down to my our '02 F-350 7.3L with 105k miles, and I want to keep this thing running strong for as long as I possibly can.
The truck has been babied for most of its life...never towing more than 10,000 lbs or so.
It has an exhaust, cold-air intake and a 6-set chip...either of the makes I'm not sure of.
Anyways, I know the diesel is reputed with its durability (especially the 7.3) but I'd like to gather some knowledge of when I should do maintenance. At what mileage should I check what, etc...
We just had it looked at when it hit the 100k mile mark, and said it was in marvelous shape.
All tips are appreciated!
Old 02-22-2013, 04:24 PM
Journeymaaann
Journeymaaann is offline
Journeymaaann is gaining momentum as a positive member of FTE.
First let me Welcome You!! to the Best place to get all the truth about your truck. I didn't know much when I got here and have been learning every day I spend a little time here. using the search feature has been a great help to me. one could search "Maintenance" and come up with tons of material. Here is a link to the 'Failure Prevention Thread' to get ya started. https://www.ford-trucks.com/forums/1...on-thread.html I just started reading. I'm sure others will chime in. Welcome again + glad to have ya!
Old 02-22-2013, 04:29 PM
tjc transport's Avatar
tjc transport
tjc transport is offline
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
welcome to FTE.
these trucks will run forever with proper treatment. at 105k miles, you are just broke in. there are a lot of trucks here with 250k+ miles on them and still running like new.
Old 02-22-2013, 04:39 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
BillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to beholdBillyBob69 is a splendid one to behold
I would not agree with item #5 in the list of the first post...
Unplugging the fuel bowl heater may keep the fuse from blowing but that also disables the water in fuel sensor.
I would rather just keep a 30A fuse on hand and know what to do if the heating element does go out and cause the fuse to blow and why.
Here is another link with a lot of maint. tips.
Powerstroke Mods and Maintenance
And a link for mods n stuff
https://www.ford-trucks.com/forums/4...ech-links.html
Welcome to FTE!!!
Old 02-22-2013, 05:22 PM
Christof13T's Avatar
Christof13T
Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
Welcome to Fte P-Wing!
You are fortunate to have that truck at such low mileage...
Regardless of miles on it... time still takes its toll.
Likely it will be time to freshen up orings in various places and flush fluids if it hasnt been done.
You definitely found the right place.
Follow the links the guys posted above and read read read.
Go stare at your motor...
Read read read read...
Stare some more...
Rinse , repeat..
Learn..
Share what you learn from your experiences...
Welcome to The Brotherhood.
Old 02-22-2013, 05:42 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
If you are using the correct oil such as Rotella T, Delo or Motorcraft etc, then you can change your oil every 7000-8000 miles with no worries. Fuel filter every 15k. Check SCA every 12k, Change auto trans fluid every 30-35k, differential fluid every 100k, transfer case fluid every 100k, brake and power steering fluid every 3 years, HPOP hoses every 10 years, serpentine belt every 100k. I've never seen a coolant hose pop on one of these trucks but I change them out every 10 years anyway.
My OEM water pump lasted almost 1/4 million miles so I replaced it with another Motorcraft unit. I am still running the OEM starter and alternator so if those things ever go out then I'll just have my original units rebuilt vs buying a reman from the local parts houses.
Enjoy your truck. Sounds like you have a nice one there.
thinksnow
08-08-2013 06:58 AM
Hnep
1999 to 2016 Super Duty
09-15-2012 02:12 PM
bradleyj
04-17-2012 02:32 PM
roman's Marine
16
12-07-2005 02:31 PM
tobetaxfree
Car/truck Buying Advice
12-07-2002 11:38 PM
Quick Reply: '02 7.3L with 105k miles- Newcomer looking for wisdom
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
