Truck Hiccuping and stuttering
My 98 explorer is hiccuping when i am stopped for more than a few seconds and when I press the gas to get going it stutters. It only does this if I am stopped at a light or stop sign for a few minutes. Once I get going again it runs fine. The check engine light is not on and I have replaced the o2 sensors and spark plugs. I am at a loss on what to do next. Any ideas?
Connect a fuel pressure gauge to the schrader valve on the fuel rail..
Key on and off in 5 seconds (no start), record pressure.
Key on/off 3 times(no start), record pressure,
Check gauge for 5 min (key off), record bleed down (if substantial bleed, check injectors/FPR)
Start engine, record running pressure..at idle, record running pressure..at 2000rpm... Philip
I'm not sure how many miles you have on the spark plug wires, but they could very easily be the cause of the sputtering too. They actually would be more suspect than spark plugs. Spark plugs can cause hard starting or a constant misfire, but won't usually be the cause of a random misfire.
-Rod
-Rod
bigmacmonday
17
02-06-2010 09:13 AM
