diesel oil in gas engine?
#31
Interesting thread. I've never used the diesel oil myself. Just reminds me of a couple interesting things I've run across.
1. This https://www.ford-trucks.com/forums/1...-visc-tsb.html
I use 5W-30 at this present time. The reason I do is because I have an actual oil pressure gauge in my truck. This tells me if my engine (229,000 miles)can maintain minimum oil psi. It does.
2. This Motor Oil 101 - Bob is the Oil Guy
Definitely something worth reading. Most on here have probably read it I imagine.
I might run the diesel oil for the detergents one day. From the sounds of it, they'll clean a motor up pretty well!
Kinda off topic maybe, but also kinda on topic
Chris
Chris
#32
My wife's Isuzu built SOHC 6VD1 engine is known for clogging the drainback holes in the oil control ring's land and then burning a lot of oil.
The rocker shafts are also known to wear.
With over 200k on it I'm not concerned about a little 'extra' viscosity when hot, but I surely want the oil to flow when cold.
The excellent anti-wear + detergent package can't hurt.
This oil has definitely made a difference with hydraulic lash adjuster (lifter) noise.
Running a high detergent oil and a quality filter all the time will go a long way towards not allowing sludge to build up in the first place.
I could care less about BS claims by manufacturers and self aggrandizing internet "experts".
Blackstone UOA tells me that T6 can easily go 7,500 miles between changes, and I will continue to do so.
laswalker
04-03-2006 05:18 PM
