Power outlets behind console on 2011 f150 lariet
My grandson broke off the cover on the 12v power outlet behind the console in the back seat area. It is a square black cover. The 110 volt outlet is next to it. I bought the part- part number: 19a487, but don't know how to replace it. Do I have to pull the console to do it, or does the old broken one come and off and the new one snap in? Any help on this will be appreciated.
Thanks
Ken
Thanks
Ken
WARNING: Disconnect the battery before servicing the direct current/alternating (DC-AC) inverter or alternating current (AC) powerpoint to prevent the risk of high voltage shock. Failure to follow this instruction may result in serious personal injury.
1. Remove the 3 screws and the storage compartment door.
2. NOTICE: Raise the selector lever trim panel only enough to access the floor console rear panel screws. If the selector lever trim panel is raised excessively, component damage may occur.
Lift the rear portion of the selector lever trim panel to release the retaining clips.
3. Remove the 2 floor console rear panel screws.
4. Using a non-marring tool, gently pry the lower portion of the floor console rear panel to release the 2 retaining clips.
5. Disconnect the AC powerpoint electrical connector.
6. Press the AC powerpoint retainers inward and remove the AC powerpoint.
