Needing Help PLEASE
Needing Help PLEASE
I have a 98 E-250 w/4.2 engine. I am getting the P1408 egr out of test range. I have checked the egr vacuum regulator and it is working as it should. I also checked the egr sensor. All are working as they should. I checked voltages and they are all in spec. I put vacuum to the egr valve and the engine does not change meaning no stumbling or anything. I pulled the valve to check it and it is working properly. Anyone know what the problem could be. Does it mean the intake will have to come off to clean the exhaust ports? But I don't understand why the engine is not stumbling when I apply vacuum to the egr valve.
ErrorS
09-07-2007 10:43 PM
