6.0 Sputtering/Black Smoke
Over the last week or so I have had several instances of my truck sputtering and stalling while driving. It has happened after I accelerate aggressively or occasionally when I am stopped at a stop light or stop sign and attempt to accelerate forward. While it is happening I have no control over acceleration but after a few good pumps on the gas and about 10-15 seconds later it fires up again like normal. During the stall process dark/black smoke comes out of the exhaust. I haven't looked into any issues yet I was really just wondering if anyone has had the same problem and would know where to start.
The first thing I would do is check the EGR valve to see if it's dirty. Here's a thread from the 6.0 Tech Folder sticky that will show you how to remove it:
https://www.ford-trucks.com/forums/4...egr-valve.html
Note: DO NOT use brake cleaner if you're going to clean the valve. Use carb cleaner, and be careful not to get any in the two vent holes.
robinma
12-17-2011 03:57 PM
